Reply
Super Contributor
Recommendations for a wireless trigger system
Hello:
I have a Canon 7d Mark II and 2 canon speedlites 580 EX II and I am in the market for a wireless trigger system.
I have been using the on camera flash as the master to trigger the optical slaves and it works in most cases, but would like to purchase a wirelss trigger system, so if you all have any recommendations, please let me know.
Thank you.
Esteemed Contributor
Re: Recommendations for a wireless trigger system
@ilzhowrote:
Hello:
Thank you.
When you say "wireless", I assume you mean "radio frequency", since "optical" is what you already have. (Hint: Optical works best when you turn the receiver portion of the slave towards the camera.) But adding an RF system to slaves that don't support it is likely to be a patchwork solution at best. I wonder if a better idea wouldn't be to sell your 580's and buy a radio transmitter and a couple of 600 EX-RT's (or just three of the latter). It would be expensive, but it would solve your problem.
Bob
Boston, Massachusetts USA
Super Contributor
Hi:
Yes, I used the incorrect terms, my fault. I meant radio triggers.
I just don't like the front camera fill flash to trigger my off cameras speedlites, even when I turn it down to 1/128 power.
So the 600 ex-rt have radio frequency so they can be used off camera? Good to know.
I guess I'll have to re-read my 7d mark ii manual to see if the camera has the radio frequency capability to pop the speedlites without having to use the pop-up flash.
Valued Contributor
[ Edited ]
The 7D Mk II has no radio wireless capability on it’s own.
You will need to buy the Canon ST-E3-RT wireless radio trigger for about $275.
Another option is a 3rd party version for about $77.
Mike Sowsun
S110, SL1, 80D, 5D Mk III
@ilzhowrote:
Hi:
Yes, in Canonese "RT" stands for "Radio Transmission" and identifies flash units that car be triggered via a radio signal - either from the hotshoe-mounted transmitter that Mike recommended or from another RT flash unit. Be careful, though. I believe there may be a Canon RT flash (not one of the 600's) that can serve as a radio slave but not as a radio master.
Bob
Respected Contributor
The 430 RT flashes are cheaper than the 600's if you wanted to save a little.
Scott
The major difference is power output.  the 600 has a guide number of 60 meters.  The 430 has a guide number of 43 meters (Canon conveniently encodes the guide number into the model number of their speedlites.)
Tim Campbell
5D III, 5D IV, 60Da
powered by Lithium
