LED lighting
Juanjo99
Tomorrow I have to shoot images at a  sports arena with flood lit by LED  and will be, using an EOS 70D, a 420EX Speedlite and probably one of the following 50mm, 35-80mm and 76-300mm lenses.
What settings should I use?
Thanks
John
5 REPLIES 5
kvbarkley
VIP
VIP
For what?
kvbarkley
VIP
VIP
You probably need a good WhiBal like reference card.
You have to check the color temperature of the arena lights. If it does not match the flash you might have to gel it.
Does the 420EX do high speed sync? You might have to darken the ambient exposure and use the flash in HSS mode to overpower it.
THanks
If the arena lights are solid state LED, there is a high probability that they will be flickering at line voltage frequencies.
Thanks
