02-28-2013 01:00 PM
Camera Canon 40D
Speedlites Canon 420ex & 430ex.
how I can use these two speedlites as slave with Canon 40D without Flash a tigger. Do the camera pop-up work as Master flash or is there any other way?
03-02-2013 04:32 PM
You can't trigger them with the built in flash unless you add slaves to trigger them. The 420 & 430 EX are triggered remotely by an infrared signal, not just a flash. These can trigger them just because it sees a flash occur.
http://www.bhphotovideo.com/c/product/774432-REG/Dot_Line_DL_0129_Slave_Flash_Unit_with.html
http://www.bhphotovideo.com/c/product/858969-REG/Photogenic_913667_PG750_Slave_Trigger.html
http://www.bhphotovideo.com/c/product/764705-REG/Nisha_FSU_Flash_Slave_Unit.html
However they can't control the output as they are just a triggering device.
03-03-2013 09:38 AM
Hi Usaf,
Adding to what was said above, we have our own device that can trigger your Speedlite 420EX and Speedlite 430EX. It is the Speedlite Transmitter ST-E2. This mounts to the hotshoe on top of the camera. When you take a picture, the camera sends a signal to the transmitter, which sends a signal to the flashes to trigger them.
On some of our newer camera bodies that have a built-in flash, the flash on the camera can function as a master. However, this was a newer function that was not available on the EOS 40D.
