HELP - 580ex ii is FIRING when it's been disabled? (in master)
kmgsakoian
Hey guys! So I have a 580exii that was working great as a master to my 430exii slave, up until last night. I was using it for a product set up, where I used the 430exii with my rapid box off to the left, and kept the flash off on the master. Now my 580exii keeps firing even though it's disabled, and it looks like it's no longer connected with the 430exii because it's no longer firing. What could have caused this? Does this sound like I need to get it fixed, or maybe a new one?
Thanks!
14 REPLIES 14
@kmgsakoian wrote:
I tried disabling the flash on the flash unit, as well as on the camera, and it continues to flash. I did notice that the flash was going off right before, not affecting the shot, so maybe as a pre-flash? But I still don't want it to go off at all. Those settings you mentioned are what I have set on both of them. I tried clearing the settings on the camera as well, and then put them back to those settings, and it's still going off when it's disabled.
I'm confused - I don't think the 430exii is able to be used as a master?
If you see it's going off, it's probably for the purpose of focusing (but normally it's done by infrared, unless you disable the infrared function -not sure you can with the 5DIII - I don't have the camera with me to check)
I'm sorry you're right, the  430exII is not capable of being a master.  It's been a while since I last used the 580EX II and 430EX II and when I used them, I used a ST-E2-RT as the controller so the 430EX II I used was always a slave...I've switched over to using the radio control 600 series.
I guess I owe kvbarkley an apology also.  Since I use the St-E2-RT as the master and it does not use a flash, I'm a bit confused on why it would work differently on the 580EXII as a master.
Diverhank's photos on Flickr
It doesn't. It just has a red filter over the flash tube.
Follow my advice and get The Speedliter's handbook, you will learn more than you want to about stuff you will never own. 8^)
Thanks so much kvbarkley, & everyone else that's helped! I actually just bought the book hah. That makes sense then, because it's working now with the slave, and I've noticed the flash is not affecting the image when it's disabled, so it must be the pre-flash.
The AF assist beam is IR by default, but the remote control beam to the slave pretty clearly isn't. I don't have a 580EX ii manual handy, but I do have a 580EX manual. It makes no mention of using IR to fire the slave.
Bob
TCampbell
You might want to pick up a copy of the "Speedliter's Handbook" by Syl Arena.
Syl is a Canon "Explorer of Light" photographer and occasional does seminars on flash photography with Canon speedlites.
He does a great job explaining how the system really works and you finally understand how to control the speedlites.
BTW, you can also just search for his name on YouTube... he has made a LOT of video tutorials and recorded seminars that you can watch.
As for the 430 not firing...
The master flash is communicating via the white strobe (which is why you see it flash even when disabled.  It only fires when the shutter is still closed and when the shutter opens only the remote flash should fire if the on-camera flash is set to 'disabled').  However... the receiver sensor is in the lower unit of both flashes and this needs a line-of-site to the flash on the on-camera master.
If you are shooting indoors, the receiver may pick up the light reflection off the walls and ceilings and flash anyway.  But if you are outdoors, there's no walls to bounce the light so the off-camera flash typically wont fire unless you rotate the speedlite body so that the lower unit (the red lens) is pointed at the on-camera master.  The 'heads' swivel so you can still rotate the head to fire the light in whatever direction you need.
Tim Campbell
5D III, 5D IV, 60Da
Enter for a chance to win!
April 20th-28th
