12-13-2012 12:58 PM
Hi, I am new to Canon and this is my first post. I just got the T3i and believe it is not possible to do FEB with the built in flash. Am I correct on that? The direction to do that is with an external speedlite flash. Which Speedlite model does FEB, and works best with the T3i? Plus I like to use bounce flash too.
Thanks
CX
12-16-2012 02:57 PM
Copperxray,
I am sorry, but FEB is not available when using the built-in flash. You will need to use an external Speedlite flash, such as the Speedlite 600EX-RT or the Speedlite 430EX II. Both of these allow you to do bounch flash as well.
12-17-2012 02:24 PM
Hi Mike,
I think you might have meant the 580EX II rather than the 430EX II. I checked and can't find how to set the 430EX II for FEB at all.
As far as I know only the 550EX, 580EX, 580EX II, 600EX-RT and the macro flashes MT-24EX and MR14-EX support the Flash Exposure Bracketing feature.
Brian
