Reply
Esteemed Contributor
Accepted Solution
Chargers for speedlite batteries
What do you folks use to charge the AA batteries in your speedlites? Yesterday I started to do my last-minute charging before Thanksgiving, only to discover that my 3-year-old Maha MH-C800S had unaccountably bitten the dust. A little poking around the Internet revealed that I'm far from the only one to have had this happen. So I figured I'd better find something else this time.
But some more Internet poking brought the discouraging suggestion that there isn't very much else out there (except, of course, the consumer-grade junk that won't charge batteries individually, has no "soft" charging rate, etc.). Is Maha (they now also use the name "Powerex") really the only game in town? My current charger (with no indication that they've changed it significantly) still gets glowing reviews, of which I'm now skeptical.
Any advice for me?
Bob
Boston, Massachusetts USA
Respected Contributor
Re: Chargers for speedlite batteries
I've been using the La Crosse Technology BC-700 Alpha Power Battery Charger for about 7 years now.
I've found NLEE's reviews on Amazon to be outstanding when it comes to batteries and chargers. He's very knowledge and answers questions fairly quickly.
Here's his 2012 update on numerous battery chargers.
[Update on April 4, 2012]
My original review was written back in August 2007. Now, nearly 5 years later, most of its content is no longer current. So I will use this spot for publishing my "Frequently Asked Questions" relating to BC-700/900/1000 family of chargers. This list is work in progress and will grow with time. Let me know if you have new questions to be added. Here goes...
[Q1] There are four operation modes on the BC-700 (Charge, Discharge, Test and Refresh). Which mode should I use and when?
[A] Most of the time you just need CHARGE mode. That means put in the batteries and select the charging current desired (500/700mA, etc)
- If you want to know how much capacity your batteries can actually hold, use the CHARGE/TEST function. Be careful not to run this operation if the batteries are freshly charged (doing so may lead to over-charging).
- If you want to find out the remaining charge in a battery, run DISCHARGE/REFRESH and record the 'mAh' number at the end of the first discharge.
- If you suspect your batteries suffer from reduced capacity, run the DISCHARGE/REFRESH operation. Or you can use this mode to refresh your batteries once every 6 months or so. Don't over do it!
[Q2] Why won't the MODE button response when I press it?
[A] Press and hold the MODE button for 3 seconds, then toggle it to change mode.
[Q3] What is the difference between TEST and REFRESH?
[A] TEST starts with a full recharge, then it discharges the cell once to determine its capacity. Next it recharges the cell to full again.
REFRESH starts with a discharge to determine the cell's remaining charge capacity, then it charges the cells back up and drain it down again to determine its new capacity. It wil repeat this Charge/Discharge cycle multiple times until the capacity stops improving. Finally it charges the cell in the end.
[Q4] My BC-700 has been discharging and refreshing for 3 days!! When does it stop?
[A] The REFRESH operation takes at least three Discharge/Recharge cycles to complete. If you use the default 100mA discharging (200mA charging) current for a 2000mAh AA cell, each Discharge/Recharge cycle takes about 30 hours! Terminate the Refresh operation and restart it using 350mA discharging (700mA charging) instead.
[Q5] What is the best charging current for recharging AA or AAA batteries?
[A] For AAA cells the default 200mA is just right. If you're in a hurry, increase the current to 500mA.
For AA cells you should increase the charging current to either 500mA or 700mA. This reduces the charge time and, more importantly, ensure that the charger will not miss charge termination signal and ends up over-charging your cells.
[Q6] How does the BC-700 know when to stop charging?
[A] The primary termination mechanism is "negative delta-voltage detection" (-dV/dt). If this signal is missed, backup mechanism include: high voltage termination, over-temperature shutdown, and safety timer (stops when total charge > 3700mAh)
[Q7] I ran a Charge/Test operation but in the end it shows a capacity reading of "000 mAh". Are my batteries dead?
[A] Most likely the charger missed the -dV/dt termination signal, and subsequently tripped either over-voltage or over-temperature shutdown.
[Q8] I used the BC-700 to recharge my Duracell 2650mAh batteries, and the capacity readings are over 3000mAh. Are those batteries great or my charger is bad?
[A] When you use CHARGE, the 'mAh' reading is for amount of charge going INTO the battery, not what is actually STORED by the batteries. Because the energy conversion is not 100%, you always need to put in more charge, especially if your batteries are old or leaky. To find out the charge stored, use either Charge/Test, or Discharge/Refresh
[Q9] I put in a set of exhausted batteries and one of them shows 'null'. Is the battery dead?
[A] If a battery has been over-discharged, its terminal voltage may fall below 0.5V and the BC-700 cannot detect it. You can kick-start it by using my "Paper Clip trick" (see customer image section for details), or by charging the dead cell in a dumb charger for a few minutes. Then the BC-700 will recognize it.
[Q10] Why can't I tell how much charge is left in my battery instantly?
[A] No battery testers in this world can do that. The only reliable way is to run Discharge/Refresh. However, you can estimate the `fullness' of your battery by looking at its voltage. When you first insert in a battery, its voltage is displayed for 8 seconds. If the voltage is higher than 1.30V, the battery is mostly full and you don't need to recharge it. If it is below 1.20V, it is nearly exhausted.
[Q11] How do I power the BC-700/1000 from my car battery?
[A] You need a CLA (cigarette lighter adapter) with 3V output at a 2.1/5.5mm barrel jack; current rating of 3A for the BC-700, 4A for the BC-1000. For example: AccuPower AP12243 Car Adapter. An easier solution is to get the La Crosse BC500 which runs off 12V directly.
[Q12] What is the REAL advantage of having an advanced charger like the BC-700?
[A] It allows you to determine the true capacity of all your batteries, and to revive those under-performing cells. Then you can group cells with similar capacities together for best result. Plus it looks cool and is a chick-magnet... just kidding!
[Q13] Is it normal for noise to come out from my BC1000 when it is charging batteries?
[A] Yes. The BC-700/1000 uses pulsed charging current at 25% 1 Hz. So when you set the current to 700mA, internally it is putting out 2800mA for 1/4 second. That's why it emits a faint ticking sound once every second.
[Q14] Why am I not able to see a charge termination even at 500 mA charge rate on my brand new AA Eneloops? (Voltage on the battery was 1.43 V when I manually pulled out. When I insert the same battery again it promptly says full!)
[A] It is normal for eneloop cells to reach at least 1.48V just before the delta-voltage drop is detected. If you remove a cell while it is only 1.43V and re-insert it right back, the charger detects a higher than expected voltage for NiMH cell, so it treats the cell as full and will not recharge it. Otherwise it could miss the delta-V detection from this stage.
[Q15] What is "charge rate" and how does it relate to charge time?
- Charge rate C = charging current (mA) / Capacity (mAh)
- Charge time (hr) = Capacity (mAh) / Current (mA) = 1/C
Therefore 0.2C means a charge time of 5 hours, for example
[Q16] What is the best charge rate?
[A] The general recommendation from battery manufacturers is to keep the charge rate between 0.5C and 1C. Higher charge rate shortens battery lifespan. Lower charge rate may cause charger to miss termination signal. In practice, a rate between 0.25C and 0.5C is preferred if pulse-charging technique is used.
[Q17] If I recharge an 800mAh AAA battery at 200mA, is there a danger of missing charge termination signal at 0.25C?
[A] No. The BC-700/900/1000 uses pulsed current at 25% duty cycle. So when you select '200mA', the actual charging current is 800mA for 0.25 second, followed by 0mA for 0.75 second. Therefore although the DC heating effect is at 0.25C, the charge termination signal is determined at 1C. On the other hand, charging a 2000mAh AA cell at 200mA is borderline too low and should be avoided.
[Q18] I have some old batteries that developed high internal resistance. Will it help by cycling those batteries in REFRESH mode?
[A] The problem with higher internal impedance cannot be reversed. Your best hope is to charge them at the slowest rate, then use them for less demanding appliances such as wireless keyboards. But if they also suffer from rapid self-discharge problem, then you should just recycle them.
[Q19] How do I find out the firmware version of my charger?
[A] When you first connect the charger to AC adapter, the rightmost column shows the firmware number. For example, '35' means firmware v35.
[Q20] How does the AccuPower IQ-328 Battery Charger compare to the BC-700/1000?
[A] Except for some very minor differences, the IQ-328 is identical to the BC1000, down to the same bugs. But it has thermal dissipation problem and will trip over-temperature when charging 4 cells at 1000mA. See details here: http://www.amazon.com/review/R1W62S0X09QMMQ/
[Q21] Is the BM200 Intelligent Charger same as the BC1000?
[A] The BM200 has a similar looking LCD panel, and seems to offer many improvements over the BC1000. But it has thermal dissipation problem and will trip over-temperature when charging 4 cells at 1000mA. Read my review on it for details: http://www.amazon.com/review/RRZI4G772IAVR/
[Q22] How does the BT-C2000 Battery Charger Tester Analyzer compare to BM200 and BC-700/1000?
[A] The BT-C2000 looks identical to BM200, but it has updated hardware and firmware to resolve the thermal problem. The latest firmware v2.1 fixed the REFRESH function and offers better user interface.
[ Edited ]
I own a LaCross BC-1000... but honestly the charger I typically reach for first is the Panasonic BQ-CC17 that came with the batteries the last time I purchased a pack of Eneloops.
My previous chargers used to require that I charge the batteries in pairs of 2.  But just occasionally I'd have a single battery that needed a charge.  The BQ-CC17 will actually let you charge an individual battery.
I also had an issue with some Eneloops that had drained particularly low and the LaCross refused to charge them, but the Panasonic brought them back.
I bought a Maha which turned out to be defective... refused to work and after contacting them it was determined that it was indeed a defective charger.  So I *was* going to return it for another but found that the particular defect was (a) not uncommon and (b) dangerous.  There were numerous reports of defect Maha chargers catching fire.  I scratched that option off the list and that's when I bought the LaCross charger ... which I used until I discovered the Panasonic charger (I still use the LaCross ... just not as often.)
Tim Campbell
5D III, 5D IV, 60Da
Honored Contributor
I got the B&H special on the 600EX RT III, which came with the Dr. Watson batteries and charger, 18 months ago.  I have not used my flash enough times [recharged it enough times] to offer an objective opinion.
Product reviews at B&H seem to make no complaints about Dr.Watson AA batteries or their AA chargers.  They have had a few complaints about LP-E6 chargers because you must use some adapter to fit onto a universal charger.
Reputable Contributor
I am looking at MH 808M. I use MH C9000 and have done since 2011 and am very happy about it, but I would like to be able to charge more batteries at the same time.
My Swedish blog
M5, 7D, 6D, D30, 1000D IR, 16-35/4L IS, 100/2,8 Macro, 70-200/2,8L IS II, 24-105/4L, 85/1,8, 50/1,4, 24/1,4L II, 300/2,8L IS, Helios 58/2
Darktable, RawTherapee, Photomatix, Luminance HDR, GIMP 2.9.5.
My experience, and what I've read so far since my charger quit, appears to confirm Tim's feeling about the Maha product line. I think I'm done with them. And my experience has also changed my attitude towards 8-battery chargers generally. If I had been using, say, two 4-battery chargers instead, a failure wouldn't have been nearly as traumatic.
So I'm leaning towards getting two of the Lacrosse BC-1000 chargers. I try to never let my batteries get fully drained, so I don't think the BC-1000's inability to resuscitate a dead battery will be a problem. If it ever comes up, maybe I'll spring for a Panasonic charger the next time I have to buy Eneloops.
I appreciate the speedy responses to my inquiry. Thank you all!
Bob
You can also 'jump start' a dead battery in the LaCrosse charger using a paper clip.
Paperclip
powered by Lithium
