Reply
Occasional Contributor
Can’t change settings on 600ex-rt in manual mode.
All the sudden my 600ex-rt is only firing at 1/1 no matter what setting I put it on. It’s doing the same on multi too but not e-ttl. It seem to change after I switched the batteries. Has Anyone come across this issue and been able to fix it?
Esteemed Contributor
Re: Can’t change settings on 600ex-rt in manual mode.
This is a wild stab, but are you sure that all four batteries are good? Cheap chargers that charge four batteries at a time usually stop charging when any one of the four reaches full power. If one or more of the others is unable to hold a full charge, that fact may be overlooked. Better chargers monitor each battery individually, but those are more expensive.
Bob
Boston, Massachusetts USA
I wondered if it was the batteries so I changed them a 2nd time and I got the same result.
Does it do this even if not connected to a camera?
Tim Campbell
5D III, 5D IV, 60Da
I did not try off camera. I was too perplexed and busy to try anything like off camera flash.
Reputable Contributor
I can't find the link but there has been talks regarding this problem on other forums.  As I recalled, this was due to a component failure in the flash and it will have to be sent in for repair.
Diverhank's photos on Flickr
Thank you.
The reason I asked about off-camera use is because the 580EX II speedlite had a known issue where the screws that snug down the foot plate would get loose... this would cause the pins to make poor contact with the camera hot-shoe, and the flash would fall out of E-TTL II mode and back to Manual mode and fire at full power (due to a loose foot plate).  But if used off-caemra (as a slave) where the foot plate is ignored, the flash would work fine.
BTW, the 600EX-RT is _not_ known to have this issue that the 580EX II had.   Canon had a free service repair for those affected by the 580EX II issue, slightly changed the design, and I've not heard of another Canon flash having this problem ever since.
Tim Campbell
5D III, 5D IV, 60Da
I would say this issue seems to be different. The flash never changes modes on its own. I think it may need a component repair. Thank you for the help though.
Hello Jaymiemetz,
We recommend setting up a repair for your Speedlite 600EX RT on our web site.
You may fill out an online repair request form at the following link to setup your repair using our online service.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
powered by Lithium
