Reply
New Contributor
600EX-RT trouble
My 600EX-RT is dumping light on TTL. I've tried turning off modeling selection CF-2 and it is not set to multi. Every time I try to lower the power on TTL...it returns to the middle bar and is dumping too much light. I can set the power to -1, -2, etc...but the minute I press the camera's shutter, it returns to 0 on the +/- rating.
Suggestions?
Esteemed Contributor
Re: 600EX-RT trouble
Suggestions?
That sounds like the result you get when you use a TTL flash on an E-TTL camera. A camera is either TTL or E-TTL, but not both. What camera are you using? Have you tried setting the flash to E-TTL?
Bob
Boston, Massachusetts USA
New Contributor
Canon5D, Mark iV...has been working fine until last shoot. Is this a setting I need to change on camera? or in flash? or both?
I had thought it would be on the flash, but I just checked my 600EX-RT, and it doesn't have a TTL setting. Make sure it's set to E-TTL, but it looks like that isn't the problem.
I don't have a 5D4, but no E-TTL camera that I've ever used has a TTL setting, So make sure it's set to E-TTL as well. If both are and you still get the overexposure, I guess you'll have to Contact Canon Support.
With an E-TTL flash, underexposure is much more common than overexposure, in my experience. Apparently that's because the E-TTL algorithm assumes that all flash is fill flash, and concerns itself only with making sure that the highlights are properly exposed.
One other possibility: Make sure that you didn't inadvertently turn on flash exposure compensation. That allows you to call for a greater or lesser exposure than the camera's metering would select by default.
Bob
powered by Lithium
