05-02-2016 10:24 AM
I was shooting an event this weekend when my 580exII when suddenly the head/flashtube "flaired", it looked very bright white and only lasted for a second. The flash worked fine for the remainder of the shoot. Wondering if this a loose flashtube or something else? Is it something I could fix on my own? Thanks for any information.
05-02-2016 10:27 AM
Could you have accidentally turned on the modeling flash?
05-02-2016 10:28 AM
No.
05-02-2016 03:14 PM - edited 05-02-2016 03:14 PM
If you were at an event, and there were other cameras and flashes in use, then you may have encountered some stray signal interference meant for another device. I'd ignore it until it happens again.
05-02-2016 03:23 PM
No other cameras there.
05-02-2016 03:34 PM
@brucenimmer wrote:No other cameras there.
Not even cellphone cameras? I'd chalk it up as a glitch, and ignore until it happens again. Blame it on a stray nuetrino.
05-02-2016 03:40 PM
No other cameras that I saw and no cell phones being used either. The same thing happened the night before while I was testing the flash unit at my home. Thanks for the answers/help.
05-02-2016 03:43 PM
@brucenimmer wrote:No other cameras that I saw and no cell phones being used either. The same thing happened the night before while I was testing the flash unit at my home. Thanks for the answers/help.
Okay, that is different. It is likely not a glitch.
05-03-2016 08:04 AM
But I guess it slightly increases the probability that he inadvertently triggered the modelling light. Or that there's a sporadic short in the unit, causing the modelling light to go on by itself.
