Reply
New Contributor
WFT FirewallSettings has stopped working
Hi I'm trying to synch my 6d with the EOS utility running on windows 8.1 64bit.
I'm getting:
I've tried to run it in Admin mode and  win 7 mode.. no sucess
New Contributor
Re: WFT FirewallSettings has stopped working
Did you get this working yet?
Im having the same problem, i bought a 70D a few days ago.
New Contributor
same here (70D, EU3)
A-C
New Contributor
Same problem here more or less. The program wants to change my firewall but cannot do it. I tried to turn my firewall off, but it doesn't work either. ( Win 10). Why cannot Canon make a program that works?!!
Honored Contributor
Just what exactly does "it doesn't work either" mean?  If you want concise answers, then you need to describe your problem better.  For example, what is it that you're seeing that makes say, "it doesn't work either".   We can't see your screen.
http://www.learn.usa.canon.com/resources/articles/2012/wft_setup_guides.shtml
Check your virus software settings.  Virus software has firewalls, too.
New Contributor
I've the same problem ("WFT FirewallSettings has stopped working") since I bought my 70D, with Windows 7 as well as after upgrading to Windows 10 on a SONY VAIO, and with Windows 10 on a HP Envy.
At first I thought it was due to SONY's own adaptations to Windows, but obviously it is not. It doesn't work with Defender ON of OFF, with the Antivirus' firewall (Bitdefender Total Security or McAfee LifeSave) ON or OFF.
Whenever I try to pair my 70D with EOS UTILITY, WFT FirewallSettings is started and I get this dialog box:
EOS Pairing Software ... Windows Firewall settings must be changed ...
After I click Yes I get the User Account Control dialog box. When I click Yes I get the following :
Sometimes, like now with the McAfee firewall off, it keeps reporting forever.
But generally it ends with the following:
In any case you get the following dialog box thereafter:
Could not change the Windows Firewall settings
If - instead of pairing - I start the program "WFT FirewallSettings.exe" with of without admin rights I get the same dialog boxes but the first one.
I've tried it with different versions of EOS Utility, like the version 2.13 at the time of the release of EOS 70D, as well as the latest version: EOS Utility version 2.14.20a.  Windows has always been up-to-date.
Sony VAIO with Intel Core i7 64 bit with Windows 10 Professional, upgraded from Windows 7 Ultimate
HP Envy with Intel Core i7 64 bit with Windows 10 Professional, Windows version 1709 build 16299.192.
Both have Adobe CS5.5 and Adobe Lightroom 6 installed.
If at least someone could instruct what settings to change in the registry, or give help in any other way.
Moderator
Hello, Th_Hoornaert,
Thank you for reaching out to Canon USA! We recommend getting in touch with our friendly support team for this in-depth issue. Support can be reached at 1-800-OK-CANON (800-652-2666) weekdays from 8am to Midnight or Saturdays from 10am to 8pm (ET).
If you're outside the US, you'll want to reach out to Canon in your country. You'll find contact information at http://global.canon/en/support/
powered by Lithium
