01-01-2014 02:39 PM
Hello I just bought a 5D Mark ii, can I use the DPP software that came with my Rebel T3 with this camera?
01-01-2014 04:59 PM
"...you can always download the newest version (an an upgrade) and be ready to start working..."
This is correct. It should work.
The 5DII is an older model than the T3, so s'ware that works with T3 should be fine with 5DII as well.
However, if you have any trouble, simply update to the latest version of DPP and that certainly will work with 5DII.
In fact, it's not a bad idea to keep up to date with the latest version of DPP anyway. It is regularly tweaked and improved, not just updated for the latest camera releases.
Later versions of DPP won't work with some relatively old DSLR models: 10D, D60, D30 for example... that generated a .CRW file instead of today's .CR2. The latest versions of DPP no longer support the older cameras and their file format. (Just get a copy of Adobe Elements... that will work fine.)
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
01-01-2014 02:58 PM
Yes - DPP handles a fairly broad range of EOS models. Canon doesn't specifically have a different version of each unique model.
01-01-2014 03:23 PM
Thank you so much!
01-01-2014 03:31 PM
No quite true. It really depends on what version is already installed on your computer because DPP gets updated with each new body's introduction. It's possible to have an older version installed that doesn't recognize a new (to you) camera BUT you can always download the newest version (an an upgrade) and be ready to start working with the newer version of CR2's.
01-01-2014 04:59 PM
Alan Myers
FLICKR & PRINTROOM
01-01-2014 10:05 PM
Thank you, I just posted a question about updating the software,, I still have several raw images that I have not processed, will updating cause me to lose them?
01-03-2014 04:08 PM
Jenette,
We would like you to let you know that updating Digital Photo Professional will not cause you to lose any images. They are stored within your computer, not within DPP itself.
We hope you have a great day and thank you for choosing Canon!
