11-14-2012 02:28 AM
Hi to all,
I have a problem with the Eos Utility Software.
I have the OS Windows 8, and I installed the last version of EOS Uility 2.12 compatibility with the new OS.
When I connect my EOS 5D MKIII or the 7D the EOS Utility not recognized the camera.
The drivers are installed , all the others programs works fine with the cameras.
Someone have a suggestion ?
11-22-2012 02:01 PM
11-19-2016 04:30 PM
@kvbarkley wrote:Download a fresh archive and re-install.
And when you do, remember this: If you're on a 64-bit Windows OS, install Version 3 of EOSU, even if you don't think your camera can use it. Installing Version 3 causes the installation of both versions (2 and 3). Then when you call up Version 3, it will determine whether your camera needs Version 2 and automatically call it up if it does. For some reason Canon describes this process in only the vaguest of terms, and users' misunderstanding of it is the basis for many of the problems reported regarding EOSU in the past two years or so.
12-03-2016 02:18 PM
I'm at a loss. About a month ago the Eos Utility stopped working. I was using version 2 since my update to windows 10. Since then, everytime I try to use it, I get the lovely message that a "problem" has occured and caused the utility to stop working. I have tried uninstalling it, reinstalling it, uninstalling windows updates, unplugging everything that was plugged into USB ports, installing utility 3, uinstalling utility 3. I'm at the point where I'm ready to throw my computer and camera out the window.
Now on that note, I really only use the utility for the downloading images and the organization aspect of it. So I guess my question is this....Is there a way to fix the utility so it actually works or does anyone have different program they use to download and organize their pictures?
10-04-2017 07:18 AM
Hello Canon World.
i need a small help from you ...i have issue with the upgrading firmware as mentioned below. i have already formated 1.2.5 and now i m triying to upgrade or upload new version. but when i clicked on the setting menu firmware to be upgraded in not highlighted.
12-27-2017 05:48 PM
Hello BOY,
We recommend uninstalling the EOS Utility application and reinstalling fresh from the web site. Then try reconnecting the camera again.
01-27-2020 05:53 PM
Crisis. In Costa Rica with my D5 MKiv. First error message: Invalid correction data for Digital Lens Optimizer. Use EOS Utility to replace the correction data.
Removed and replaced EOS Utility 3 (Mac). No help.
Updated firmware. No effect.
Tried a shot. Second error message: Err 70 An error prevented shooting. Turn the camera off and on again or re-install the battery. Done and done. Also changed batteries.
01-28-2020 02:26 AM
knuk,
I am sorry to hear this happens. We recommend filling out an online repair request form at the following link to setup your repair using our online service.
www.usa.canon.com/repair
01-28-2020 06:05 AM
01-28-2020 08:21 AM
Hi, Knuk! If you're based in Canada, we recommend contacting our colleagues at Canon Canada for support. You'll find them HERE.
Hope this helps!
01-28-2020 08:28 AM
01-28-2020 11:16 AM
Dear Knuk,
I had this problem once before (and I am not sure exactly how I solved it - but I will look up and come back to you), the problem is not with the Program EOS Ulitity, (therefore you can install it any number of times with no solution), the problem may be with your Computer, (MORE THAN ONE CAMERA LISTED ON YOUR COMPUTER or the same camera listed multiable times) your computer is not matching up your camera with the program, (you need to go into "control panel" and remove these extra cameras) so you have none, then restart computer and connect your camera again and all will be OK. HUGH
