11-14-2012 02:28 AM
Hi to all,
I have a problem with the Eos Utility Software.
I have the OS Windows 8, and I installed the last version of EOS Uility 2.12 compatibility with the new OS.
When I connect my EOS 5D MKIII or the 7D the EOS Utility not recognized the camera.
The drivers are installed , all the others programs works fine with the cameras.
Someone have a suggestion ? ![]()
11-22-2012 02:01 PM
11-14-2012 02:46 PM - edited 11-14-2012 03:21 PM
I am running Win8 (upgrade from Win7) and EOS Util 2.11.40 / 5D MKIII and it works - should I not upgrade to 2.12? ![]()
Update: I updated to all the latest Software, IBEX, DDP, and EOS Util. It all still works fine - camera control / shooting, etc.
As a side note to anyone from Canon reading this - the updates don't show the latest firmware when I select Windows 8 x64 as my OS. That's probably a site error as the firmware updates have nothing to do with the OS and only the camera - they should probablt show up for all Operating Systems.
11-14-2012 06:52 PM
I also cannot get Win8 x64 to connect to EOS Uitility. I've tried it on two PC's running Win8, neither work. Works fine on the same hardware with Win7 or xp, in fact I'm running both on a virtual machine (vmware) and attaching the driver to the VM works OK. Basically MTP portable device drivers get loaded and it just looks like a flash drive - but EOS Utility can't see the camera.
Canon is aware that it works for some people and not others according to the various posts that are showing up on dpreview, canonrumors, and fredmiranda. Eventually they will have to figure it out.
11-14-2012 07:11 PM
11-14-2012 10:12 PM
In the Device Manager, I get a Canon 5D III under "Portable Devices" and it shows up like that in the same area when I explore "My Computer".
What shows up in your Device Manager when you connect the camera?
11-15-2012 02:27 AM
In my device manager is all OK. I can see the 5DmarkIII icon and in property panel it says me that the device works fine and all drivers are installed. ![]()
11-15-2012 08:33 AM
I have the same problem.
I have removed the software, switched off and reinstalled it.
Sometimes the camera (7D) will show up on windows explorer (under computer) and sometimes it wont.
I have check that I have .NET 3.5 installed.
So now I have given up trying to use EOS utility
11-16-2012 11:34 AM
I have the same problem with Eos Utility: will not download my photos. Recognizes the camera. Latest version of Utilities.![]()
11-16-2012 06:05 PM
Alexpado,
I am sorry to read that you have difficulty with Windows 8 and EOS Utility. Version 2.12.0 should allow you to connect to the EOS 5D Mark III on that platform. Since you mention other computers being able to connect without an issue, it must be something specific to your machine. I would try uninstalling the software and then starting again from scratch. Install the Utilities off the CD and then update off the web site.
I hope this helps resolve the issue.
11-16-2012 08:35 PM
Hey Tim - There are many of us with this problem on Windows 8 x64. I have two systems that don't work no matter what I do (uninstall / reinstall etc). The MTP driver gets loaded as if it is a flash drive, which works fine, but EOS utility cannot see the camera. I've tried two such x64 systems, and they both behave the same. I've attached the driver dialog box snapshot below.
Your guys at Canon R&D need to try a few different physical installations and I"m pretty sure you'll find that there's some sort of driver problem.
Wayne
