Reply
Occasional Contributor
Accepted Solution
EOS Utility Not Working with MacOS Sierra
I am using a beta version of the new MacOS Sierra. In the early stages of the beta, the EOS Utility worked fine but in the past 2 releases, it has failed.
I am using a Canon EOS 700D and v2.14 (2.14.10.2) of the utility. I aslo use an iMac 2009.
I have filed a bug report with Apple on this one, but there has been no action on their part yet to sort the issue. In any case, I suspect it may be left to Canon to update their software in line with the OS release.
Just wondered if anyone else had experienced the problem and if Canon were aware of it?
Honored Contributor
Re: EOS Utility Not Working with MacOS Sierra
"I am using a beta version of the new MacOS Sierra. In the early stages of the beta, the EOS Utility worked fine but in the past 2 releases, it has failed."
So what.  That is why it is called a Beta.  Don't blame Canon because their existing app may not work with a Beta.
So what??? Is that meant to be helpful? I did not criticise Canon, merely raised the issue and wondering if others were experiencing the same problem. It also acts as an alert to others considering upgrading that they may have issues. It is called 'communication'.
This is my first foray into this forum and if this is the type of individual who contributes here, then it can't be much of a forum!
Honored Contributor
[ Edited ]
"So what??? Is that meant to be helpful? I did not criticise Canon, merely raised the issue and wondering if others were experiencing the same problem."
That's correct.  "So what."  You're in the wrong forum.  Take it up with that Beta's forum.  It's not a Canon issue.  It's Apple's.
I am being helpful.  You are more likely to find users of that Beta in the Apple forum than you will around here.  Excsue me for being so blunt and direct, but those are the facts.
Read the initial post again properly. I have reported it to Apple. I have taken other action also to seek advice on Apple forums without success. I am now here to see if there is anyone in the same situation as myself who has experienced this problem as Beta releases of Apple OS software is now available to the public.
As far as I know, there is no way to feedback to Canon using their software directly and, therefore, I am hopeful that the Mods or Admins here may be able to do that. It is how it works on other software sites.
And you are wrong about it simply being Apple's problem. When an OS is changed, it is down to the developers within each company to update and issue compatible software. That is why feedback processes exist. Furthermore, if you want to read about the Appleseed project, you will learn more of what I participate in. In the past, I have referred issues to Apple during testing and follwing investigation by Apple engineers, I have been referred to the third party to advise them of incompatibilities.
At this point I cannot tell if I have a compatibility issue with my machine, my camera, my software, or what! That is why I am asking. A process of gaining as much information as I can about this particular incompatibilty and, if possible, hear from others who may have a solution to that.
As for being blunt and direct, you don't need to be rude to make your point. I think most of us are aware of how internet communications work by now!
Honored Contributor
"And you are wrong about it simply being Apple's problem. When an OS is changed, it is down to the developers within each company to update and issue compatible software."
Obviously, you do not understand what "Beta Version" actually represents.  So, I'll tell you.  Beta users are voluntary guinea pigs.  You are testing the software for bugs, at your own risk.  You report those bugs to the party that released the Beta, not to third parties.  In fact, beta testers will typically have dedicated "beta platforms" for conducting tests.
If you expect thrid party develiopers to change their existing software base to accomodate a bug ridden beta release, then you need to stop using Betas.
Esteemed Contributor
To be fair to the OP, he inhabits a different world from the one with which you and I are familiar. Apple has repeatedly shown its indifference to problems caused by the lack of backwards compatibility of its operating systems. Its users are expected to try to bully 3rd-party software developers into conformance and, if unsuccessful, are free to "shoot the messenger" who delivers the bad news. Every time Apple delivers a new OS, we hear the same whine. It's nothing new.
Bob
Boston, Massachusetts USA
Honored Contributor
Okay, I'll concede your point.  But, the OP doesn't seem to realize that a Beta version is a prototype, not a release, The release version could be subject to dramatic changes from the Beta before it is officially published.
From the layout of your post, it's not clear whose point you're conceding. But note that I did not write that part that lets Apple off the hook.
Bob
Honored Contributor
"From the layout of your post, it's not clear whose point you're conceding. But note that I did not write that part that lets Apple off the hook."
I was conceding your point about the OP coming from a different world.  Sorry, for the confusion.  It was separated by a line.
powered by Lithium
