Reply
New Contributor
DPP4 CRASHES
I have just downloaded DPP 4 and it crashes constantly every time i open it. i am using windows 10. Any ideas?
Honored Contributor
Re: DPP4 CRASHES
@scottkincaidwrote:
Okay, but what brand of PC?  Does it have the proper specifications to run DPP.
If you have Windows Media Player, then you will want to disable all features related to automatically hunting and searching for new media files, and automatically adding them to the catalog.  This can be a time consuming process the first time you run WMP.  Canon’s DPP uses some of the drivers that get installed with WMP, and have long suspected DPP is doing the same thing, doing whatever the default behavior is on your PC.
New Contributor
Re: DPP4 CRASHES
[ Edited ]
Hi, thanks for replying. The laptop is a Lenovo Thinkpad T410 so should have the spec required. I have being using DPP 3 for 2 years and no issues. If it has being running DPP3, do you still think it could be an issue with WMP?
Honored Contributor
Re: DPP4 CRASHES
Actually, it does not. I think your Lenovo is the problem. It seems to lack the horsepower to run today’s 64-bit software.
https://support.lenovo.com/us/en/solutions/migr-75387
My research shows that it is from the generation of laptops that could run 32bit Windows XP, and the most recent OS that it supports is Windows 7.
New Contributor
Re: DPP4 CRASHES
Hi, Thanks for reply but my Lenovo T410 is a 64bit version which has been upgraded to Windows 10 professional and have had no issues, until now that is. No worries will just stick with DPP3 for now.
Super Contributor
Re: DPP4 CRASHES
Are you using DPP4 to process CRW. or CR2. files?
Honored Contributor
Re: DPP4 CRASHES
Okay. I stand corrected.
Super Contributor
Re: DPP4 CRASHES
[ Edited ]
Yesterday I upgraded from DPP 4.7.2 to 4.8.2 and had repetive crashes for the first time ever with DPP.  My best guess for what triggered the behavior was I had navigated to a subdirectory that contained a mix of files and DPP didn't seem to like that environment.  After three crashes I got it to stay alive long enough to move from that directory and no more problems since.
I am running it on a HP Z820 workstation (Win 10 pro, dual Xeon CPU, 128 GB memory, Nvidia graphics card).  I also noticed that the latest version seems to take a little bit longer when working with a RAW file when digital lens optimizer has been selected along with significant noise reduction.  It has gone from 4 to 5 seconds with 4.7.2 to maybe 10-12 seconds with 4.8.2.  Hopefully a more powerful graphics card will help once they become available from the hopeful decline of the crypto currency mining bubble that is gobbling up all of the cards.
I also note that running 4.8.2 during this processing delay CPU utilization never exceeds 15% while it would spike briefly to the 60% range with 4.7.2 although the sustained usage during the few seconds of processing wasn't very high with 4.7.2 either.
Rodger
EOS 1DX M2, 1D M2, EOS 650 (film), many lenses
New Contributor
Re: DPP4 CRASHES
CR2 Files.
powered by Lithium
