Reply
Esteemed Contributor
Re: Converting CR2
The beauty of Time Machine is that it keeps old files as long as possible and then deletes old ones only as needed to make space for new ones.
Occasional Contributor
Re: Converting CR2
Thanks KV.
Re: Converting CR2
are ALL files unreadable/UNopenable in ANY program, viewer, or just in PS??
a few years back I had all files stored on a windows-platform pc hard drive display as being corrupt. months later i discovered these files were NOT corrupted, when by accident I discovered those "corrupted" files were accessible via ms-dos!! i eventually moved all those"corrupt" files from the internal hard drive to an empty eHD, and they were all later viewable and usable. hope this helps
Freelance professional photog in WNY and SW Spain
my site and Vision http://smu.gs/179OEOf
my wifey's images http://bit.ly/2cbeXJF
Re: Converting CR2
Yup, ALL the corrupted files (5K or more) are unreadable in any program using both Olympus and Canon RAW readers; also, LR and PS cannot read them. I did send files to Olympus and they said they were unreadable by any of their methods as did Canon. Seems like almost all avenues have been tried - but there is always a corner or niche that may have just the right software - i'm keeping my eyes and ears open.
Re: Converting CR2
find a friend with access to windows and get into MS-Dos and see if the folders and files are there. if so, whilestill in MS-Dos, copy some test files to a eHD and see if they can be accessed in that same computer. good luck
Re: Converting CR2
There is no MS-DOS. There *is* a command prompt.
Re: command prompt
[ Edited ]
thanks kvbarkley; i stand corrected!! In ALL of my references to MS-Dos above, just change that to "command prompt"  Smiley Wink
Re: Converting CR2
And since the two are only superficially similar, there's no guarantee that something that once worked under MS-DOS will work under a Windows command line.
Bob
Boston, Massachusetts USA
Honored Contributor
Re: Converting CR2
[ Edited ]
I believe what has happned is that the two Operating Systems have swapped roles.  MS Windows used to be an application that ran under MS-DOS.  I think it began with Windows 7, the command prompt is now an application that runs under Windows.
Re: Converting CR2
Windows XP was the first NT (non-MS-DOS) based Windows for home users.
https://en.wikipedia.org/wiki/Microsoft_Windows
powered by Lithium
