Can I use more than 1 camera with EOS utility simultaneously?
Vector
I have to manage 5 canon cameras to make them shots simultaneously.
Is it possible to do this?
Thanks.
2 REPLIES 2
cicopo
I can't think of a way to do it. You'd need to have a signal go to 5 ports on a computer or hub at the same time which to the best of my limited knowledge isn't a normal operation. I suspect you could do it with things like Pocket Wizards or by modifying 5 wired remote cable releases to be operated by one's button.
TCampbell
There are companies which specifically make products to do this (trigger multiple cameras to fire simultaneously.)
Breeze Systems seems to come up a lot in search results -- you might research them.  (I have never used them.)
Tim Campbell
5D III, 5D IV, 60Da
