08-13-2015 11:35 PM
Where is the User Guide for the Camera Connect App? Also, why doesn't his app transfer images with the location information?
That being said, I have successfully installed and used the app with my G7X. My informal User Guide for using this app is as follows. Any suggested "improvements" to this guide would be appreciated.
Getting Started and 1st Time Connecting
12-28-2016 05:01 PM
Ni npsit,
Thanks for all your effort.
I had configured my camera to connect to my home wifi and ttherefore the camera's hotspot wasn't wroking. I had also set-up an account on the CannoniMage Gallery platform, registered the product, and began the configuration to web services.
I did a reset as you seggested and the Camera Connect app via the camera's hotspot works. Pretty cool.
Now I cannot connect the camera to the webservices after the reset. I suspect I also need to delete the product from my Cannonimage gallery and recreate it. My suspicion is based on the errors that happen when going the the rpocess of add webservices on the phone.
Do you know how to remove a product from the Cannon Image Gallery platform? I tried the google thingie and help files, but can't seem to find a way to get rid of it.
BTW, is it jsut me or is it odd that no one from Cannon is helping on this forum?
Thanks again for all your time and effort.
12-28-2016 05:11 PM
Hi, patrickj!
Welcome to the Canon Forums and thanks for your post! Which camera model do you have?
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. We do hope someone is able to assist! If this is a time-sensitive matter, of if you are looking to get support from Canon, please reach out to our US-based technical support team via Email at http://bit.ly/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666).
Thanks!
12-28-2016 11:56 PM
I have never tried to change my Canon iMage Gallery account but you may want to "Cancel" your CGI account in Edit Profile on the web site (not in the App).
it is also a mystery to me why Canon doesn't participate in their own Forum but I guess it goes along with their view of "support" which is minimal.
02-13-2017 09:43 PM
Since last month, I cannot connect Galaxy Note 3 with Canon g7x mark ii. Previously, there was no problem connecting. Other devices can still connect with this camera and other camera software programs also can connect with Galaxy Note 3. Whenever I try to connect, it shows "Connection to the camera failed". Please refer to the pictures below and advise how to restore this connection / fix. Thank you.
03-02-2017 10:08 PM
Hi JJUN83,
If you haven't already done so, please update the Camera Connect App from Google Play. Once that's complete, please erase your camera's Wi-Fi settings, then re-enter them.
03-01-2018 12:09 AM
Richard, I have a similar issue. It appears that I can only connect my EOS1300D (Rebel) by WiFi to one device in the Camera Connect app (e.g. smartphone or iPad). If I want to use a different device I have to completely reset WiFi settings on the camera to set up the other device. As I have the app on multiple devices and wish to use different devices at different times (not simultaneously), is there a way to fix this problem e.g. have a common password as happens for other internet devices? Please advise.
03-01-2018 01:42 AM
I had a similar problem with my G7X until I discovered that if I first selected the view photos button and then the antenna icon button on the back of the camera, I can then select either my iPad or iPhone. If instead when I push the WiFi button on the side of the camera, it will only connect to the last devise used. It is another “trick” that is not discussed in any Cannon manual I have seen.
04-10-2017 09:40 AM
Hi
I am trying to use the remove shooting feature but when I click on it I get a message come up saying 'cannot use this function with the current settings on this camera for images viewable via connection'.
Everything else about the app works fine. I'm using a Canon G7X Mark II and connecting to an iPhone 6.
Any help would be much appreciated.
04-10-2017 05:35 PM
Hi Katie_louisev,
Thank you for posting.
When using the remote shooting mode, please set your camera to one of the camera's "Creative" modes: "P", "Tv", "Av", "M" or "C".
04-19-2017 01:07 PM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
