09-24-2016 05:30 PM
THANK YOU, THANK YOU, THANK YOU!! The manual was pretty much useless to me, but following your instructions I was able to connect and transfer photos the first time I tried.
10-06-2016 05:20 AM
I recently upgraded to IOS 10 on my iphone6. After that the Canon Camera Connect software does not work. Cannot connect powershot S110 to iphone6. I deleted and reinstalled the app. Still does not work. I then installed the outdated Canon Camera Window software AND IT WORKED !!!???? How can I get the Canon Camera Connect software to work ???
10-07-2016 10:44 AM
Ridiculous that a major corporation like Canon seems to have a software / firmware division run my a bunch of amateurs. These type of constant failures are unacceptable.
10-07-2016 11:55 AM
I am able to still connect my iOS 10.0.2 iPhone 6 to my G7X camera. If you are having problems connecting, try to reset your camera (See post 22 above for info on resetting camera). Good luck.
10-22-2016 09:13 AM
I am using a Canon sx60hs and an iphone 5 with the Canon Camera Connect App. I start logging before taking photos. I can then connect the camera to the Iphone. The camera/phone connects OK. I can view images. I can do remote shooting. Adding locations adds the same location to all the photos, the location when I started logging. The system used to work for me but now it doesn't. Anyone any ideas?
10-22-2016 11:13 AM
I am not able to use my canon 70 D on iphone 7 look like new update on app destroyed the app.
10-22-2016 01:07 PM
Have you checked to see if your camera has the same time as your iPhone? Location logging requires the two devices to have their clocks in sync. I am not to sure how close they need to be (within 1 minute, within 1 hour, etc.?).
10-22-2016 01:15 PM
The times are the same on both devices. I have been a long way out of sync on my travels and it always seems to work OK. I think I have been hours out and it as still worked.
10-22-2016 01:20 PM
I am able to still connect my iPhone 6 with Camera Connect 1.3.20.49
I did notice that in order to connect with iOS 10.0.2 I had to select "Renew Lease" after selecting the Canon wifi signal to get things to work. I only had to do this once and the next time it connected as normal. Give this a try...
10-27-2016 11:00 AM
I have a SX710HS it connects great to my iphone. My husband has the same phone and we can;t connect to his. IS it limited to 1 connection?
