Reply
New Contributor
Accepted Solution
80D and Lightroom
I have a new 80D and have downloaded a free trial on LR Classic CC.  I'm unable to import the .CR2 files.  Says they are not recognised.  Having a problem talking with Adobe support to find out whether the version to buy is compatible.   Any advice?
Esteemed Contributor
Re: 80D and Lightroom
Sure. Use DPP (the Canon editor that came with your 80D) instead, at least until you can prove that you actually need Lightroom. (And be prepared for the possibility that that may be never.)
Bob
Boston, Massachusetts USA
I agree with Bob that DPP may be all you need, but you will never know if you can’t compare to Lightroom.
The 80D should be compatible with Lightroom Classic CC.
Try opening the files in DPP to ensure they aren’t damaged/corrupt.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
Honored Contributor
[ Edited ]
I agree.  What computer OS are you using?  I agree, that you should try Canon’s software first.
You’re not going to [find] much in the way of Adobe technical suppport around here, unfortunately.
Occasional Contributor
Lightroom works with the 80D but it will need to be uodated. I use it on both a Macbook Pro and Windows 10 machine.
New Contributor
Thanks for all the advice here - much appreciated. I have discovered that part of the problem was that I wasn't updating things properly, Proper updates and following the advice here, and I'm now good to go.
powered by Lithium
