10-08-2016 11:52 AM
My wife has an hf r400. I would like to get the clip off the camcorder and onto my computer (win xp sp3). I thought to use the wifi cability but I use mac address filter and do not know where to find the mac address of the camcorder. Then I thought to read the sd card directly; windows doesn't recognize it. So before I start playing with software .... Where do I find the mac address of the r400? and What is the format of the sd card?
TIA
Kim
10-11-2016 01:11 AM
Hello Timmib,
When connecting the VIXIA HF R400 to a computer via an access point, the MAC address can be viewed after the connection has been established. In most cases, its a matter of pressing the WPS button on your router and then touch the camcorders screen. This is the easiest method to use if you are on a WPS network.
The format employed for the media cards is exFAT.
10-11-2016 01:11 AM
Hello Timmib,
10-13-2016 03:21 AM
Greetings Tim,
Thanks for your answer!!
Be well,
Kim
