Reply
Occasional Contributor
Re: Pixma Pro-100 printing very dark
 it's mainly the gray or black, it's printing a lot of dark blue instead of any gray
Esteemed Contributor
I can’t help with that software.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
New Contributor
 Hi jrhoffman75
I followed your advise having had the same issue as some with darker prints compared to the image viewed on screen. I had the bonjour version of the printer driver installed which i have now replaced with the IJ one you mentiond. My screen is calibrated with an xbrite colormunki dispay and the test image prints out perfectly. Is there any further steps I need to take as you asked Len1010 to report back!!
Any help appreciated.
Mark
Hi Mark. What problem are you still having? If the test image is printing out correctly and you like the way it looks then just be sure the monitor display is as close as possible to looking like the print. (My monitor is set to 80 cd/m^2 with xRite. I edit in a dim room and there is no light shining on my monitor surface. )
New Contributor
 Hi jrhoffman75
The image exposure still looks brighter, even set at 80, but I suspect this is largely due to the 5K retina display on my iMac. I will play with the brightness further to try and match it, but I'm happy the colour reproduction is pretty good. Thanks for your help.
Regards
Mark
Ok, I have PS, a calibrated monitor. I have done the no match setting and STILL have under exposed prints. I am running a windows machine. I don't see the settings "Canon My Printer' So maybe i am just stupid but a detailed explaination on how to totally disable printer controls would be helpful. Thanks ! Steve
By "no match" do you mean Main->Color/Intensity->Set->Manual->None?
Can you post a screenshot of your Photoshop print settings?
 " By "no match" do you mean Main->Color/Intensity->Set->Manual->None? "
Yes, exactly. I also went to the 'canon utilities' and found the canon my printer, the setting there are the same as when you go to the print settings. My monitor is calibrated using a 'Spyder' 5, PS settings is RGB 1998 Photo is also taken RGB I don't want to have to print out a 'zillion' prints to finally get one decent one. Ink is expensive. Any ideas ? Thanks, Steve
http://www.outbackphoto.com/printinginsights/pi049/essay.html
Download this test image. Open it in your software. Do not make any adjustmenst. Print it. How does the image look?
I'd say about 2 stops underexposed, but a definite improvement. so, what is this telling me? I would say the colors are accurate, smooth graduations, skin tones are accurate. Say, if this print was my photo, i would adjust the exposure slider in CR to '10' contrast the same amount and the 'whites' around 5
powered by Lithium
