05-19-2018 11:28 PM
Hello, I'm using a Pixma 100 with Photoshop on macOS Sierra.
I have selected "let Photoshop manage colors." and I selected the Canon color profile for Luster paper (Luster 1/2). However, the printed colors look so different from my screen preview (the one Photoshop says should match print colors) that I have a feeling that color management is just broken somewhere.
The differences are that blues, violets, and magenta are washed out or low contrast, and images often look excessively green.
05-20-2018 09:22 AM - edited 05-20-2018 09:32 AM
Since you are on a Mac there are some things to check.
Go into System Preferences->Printers & Scanners and make sure that you see Canon Pro-100 and that "Kind" says Canon Pro-100 series. You do not want to see AirPrint or Bonjour.
If not, delete the printer, click "+" and wait for IJ Series to appear; it could take several minutes.
You want the settings to look like this:
You could also install and print from Canon Print Studio Pro. It makes sure all the right "switches" are set.
05-27-2018 04:21 AM
The problem was that I was connected via AirPrint. Works great now.
