02-01-2014 03:11 PM
Have downloaded the installation software (zip file), but when I run it (even as administrator) it will start and then freeze. OS is Win8.1. Have even shut down the firewall. Same problem. Anyone experience the same issue - have a suggestion for getting around this. Just purchased a Pixma Pro 100. Thank you.
Osprey
02-03-2014 09:28 AM
You have to have the original DVD that came with your camera installed before you can d/l and re-install it from Canon.
I don't know why, that is just the way Canon did it.
02-03-2014 09:28 AM
02-09-2014 11:46 AM
Thank you. I removed all Canon items I could find, then reinstalled and Print Studio Pro loaded and worked, at least for Photoshop. For some reason, did not for Lightroom. Doing some analysis to see if I can determine why.
Thx again.
Osprey
02-09-2014 11:49 AM
You find it under "File -> Plug-in Extras" in Lightroom
02-11-2014 09:34 AM
When installing did you tell it to do both LR and PS?
02-03-2014 05:09 PM - edited 02-03-2014 05:10 PM
If you don't have the original CD you can go here:
Download the EOS Solution Disk
