Reply
New Contributor
Canon Pixma Pro 100 - 13x19 Prints Not Working
[ Edited ]
Help!  I am having a terrible time trying to print 13x19 prints on Canon PIXMA Pro 100.  I figured out how to get the A3+ paper, but 90% of the time I get a two flash orange alarm (no paper) when there is a 13x19 sheet loaded (this happens from both manual feed and rear) and on the 10% of the occassions that I am able to print, it prints on 1/4 of the paper.  I am trying to print from a mac (one a macbook pro and the other a mac pro) using Preview or Photos.  All software and drivers up to date.  EXTREMELY FRUSTRATING - help!  I am using Canon Photo Glossy II paper and I select the A3+ borderless to print.
Thanks!
Esteemed Contributor
Re: Canon Pixma Pro 100 - 13x19 Prints Not Working
First verify that you are not using the Bonjour version of the printer. Go to System Preferences->Printers & Scanners and see if the IJ series version of the printer is installed. If yes, select it. If not, click the “+” to add it and wait. It could take several minutes.
Be be sure you are using the latest version of the Canon driver.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
New Contributor
Confirmed on both fronts and still having this issue.
Does it happen if you don’t print borderless?
New Contributor
turning of borderless solved the problem - does that mean that borderless won't work for 13x19?
I’m not at home, so I can’t check. Go into the On-Screen Manual and search borderless.
I had a similar frustrating time with my PRO-10 ... but then realized what that the paper didn't feed as readily as expected.  All I had to do was apply very gentle pressure with my finger to help the sheet feed and the problem went away (on my printer it only happened with 4x6" prints... I often use those for proofs before I put in a big sheet.  My big sheets typically feed without issue.
Tim Campbell
5D III, 5D IV, 60Da
powered by Lithium
