12-07-2022 04:53 PM
Running Ventura 13.0.1 on a Mac
Using PS 2023 v23.0.1
Using a new Canon ImageProGraph Pro-300 printer.
During the printer install, it recognized LRC and installed the proper plug-in for printing from LRC but, the install did NOT recognize PS and did NOT install the plug-in so that I could print from PS using File/Automate/pluginname.
I have rerun the Plug-in Install program multiple times but the plug-in never installs in PS.
Posted this question a few days ago but, don't see it listed.
Help would be appreciated.
12-08-2022 09:41 PM
Thanks for the link.
The video is worth watching but, it does NOT address the issue I reported. When I ran the driver install, everything worked accordingly but the install program ONLY RECOGNIZED LRC and did NOT install the PS Plug-in files Consequently, PPL is not listed in File/Automate within Photoshop.
I fixed this by copying the two .plugin files in the PPL/Install Files/PSPlugin folder to mymac/Adobe Photoshop 2023/Plug-ins and restarted PS.
I can now start PPL in PS, LRC or in stand alone mode.
12-08-2022 12:25 PM
This you tube video solved this issue - finally!
12-08-2022 09:41 PM
12-18-2022 07:58 PM
Thank you, I experienced the same issue, and now PPL works in PS2023, Thank you
11-14-2023 02:31 PM
Where did you get those PPL files, don't find it on my iMac Running OS 14.x with PS CC 2024
thanks in advance for your help
Michael
02-14-2024 01:01 PM
Thanks for sharing this solution. It works.
I was having the same problem with a newly installed Pro300 (Feb2024) and wondering why Canon have not solved the issue.
12-08-2022 02:05 PM
Thanks! Started watching it but, it is almost 2hrs long so, I will watch in pieces.
He started out blaming this on Apple, which I question because the plug-in install WORKS for LRC... just not for PS. The installer, the plug-ins and the apps are ALL CANON... not Apple.
12-08-2022 02:45 PM
The printer driver for Apple can be an issue and in Ventura I don't event see where I can change the driver.
BUT I did manage to download the new drivers and my PPL now works in Photoshop again. That info is in the very first 10 minutes.
12-11-2022 09:58 AM
I believe that the driver upgrade procedure is:
Periodically, check the Canon website - Software/Drivers for your specific printer.
If a newer driver is available for your printer than what you already have, you decide whether or not you want to download/install it.
You run the dmg file which in turn, upgrades your current driver.
I do not believe there is another process to "change the driver" as you mention.
12-08-2022 03:49 PM
" I question because the plug-in install WORKS for LRC..."
Perhaps so but it isn't a confirmation it works with every program.
