04-01-2024 01:16 PM - last edited on 04-01-2024 01:20 PM by James_C
I print on a Canon Pro-1000 connected via USB to a windows 11 PC. I had been printing using either PS or LR (both most recent versions) but loaded Professional Print & Layout for more accurate printing with fewer 'reprints'. The plug-ins for Professional Print & Layout are loaded and fully functional in both LR & PS. Photos correctly load from LR & PS into Professional Print & Layout and all is good until I press print.
I get an error in the print Q stating to check the UI (not sure what this is) or the printer panel - no further info. I note that the printer que shows an IP address for the Pro-1000 - should it if connected by USB cable and the LAN setting set to USB?
I can still print directly from PS and/or LR. can anyone help??
04-01-2024 04:18 PM
embarrassed to say - the issue was in Professional Print & Layout set-up - it selected the printer and forced an IP address even though the printer was configured in the printer and PC as USB (both wireless and network configurations were not made).
I forced Professional Print & Layout to recognize a USB printer and everything works.
04-01-2024 04:18 PM
