05-04-2013 04:26 PM
I want to scan photos as 600dpi tiff's and save them to a USB flash drive, but my canon mg6220 won't
let me-incorrect format. Any ideas or suggestions would be greatly appreciated.
Thanks, Fred
05-06-2013 10:32 PM
Hi fredno,
If you are scanning directly to the USB drive using the operation panel, you are limited to using either JPG or PDF format. To scan TIFF, you would first have to scan the images to your computer, then copy them to the USB drive.
05-06-2013 10:32 PM
Hi fredno,
07-23-2013 11:14 PM
hi
that 's a solution . but how about using TIFF scanner to scan photos as 600dpi tiff's ?I found that by google. Im trying to figure this out.
12-19-2013 02:08 AM
Hi, nesca.
I am also testing the related Tiff scanning projects about using Tiff scanner to scan photos as 600dpi tiff's. Do you have any ideas about it? Or any good suggestion? Thanks in advance.
Best regards,
Arron
