07-28-2015 03:45 PM
mx892 -- colors on glossy photo paper is splotchy. any help would be appreciated. Jan
07-28-2015 05:47 PM
Sometimes that happens when the wrong paper/profile combination is used. What paper are you printing with? What printer setting are you using?
07-28-2015 07:36 PM
I have not changed papers as I use Papilio Inkjet clear waterslide decal paper and have used this brand for years. I am using the same settings and same software to print from. I got a not from support and they tole me to check the nozzle pattern and it was really good but I still did a cleaning and a deep cleaning with hope but still not printing right. I went on website to see if I needed to update but there were several options so did not know what to pick.
Thank you for your response. Jan
08-01-2015 07:07 PM
I use clear decal injet paper from papilio and am using the same settings I always use: Glossy Photo Paper and click the boxes in the efftects : Vivid photo and the clicks under that. Thank you, Jan
08-12-2017 10:00 AM
Did you get a fix for this? I just bought some Papilio (white) waterslide paper for inkjet and the images keep coming out blotchy no matter what setting I try! I'd love to know if you figured out the right one. I have a Canon ix6820. Thanks!
07-28-2015 06:10 PM
07-28-2015 08:06 PM
07-30-2015 09:31 PM
Yes, same paper and same settings. I have gone through and done all the clean ups on the maintenance page, like deep cleaning, alignment, roller cleaning etc. and still it is not working. I am so frustrated. Thank you for your replying to me. Jan
07-30-2015 09:51 PM - edited 07-30-2015 09:53 PM
