10-24-2015 12:13 PM - last edited on 12-01-2023 09:00 AM by Danny
I have a Canon PIXMA MX722. When scanning a document through the ADF or directly from the glass plate the document has a 1 inch thick vertical black line about 1 inch from the hand margin. When scanning a PDF it's on the right side but JPEG is on the left. I have cleaned the glass based on suggestions from other posts. I'm not sure what else to try to resolve this issue. Any help is greatly appreciated!
01-24-2017 12:26 AM
I have the same black line anyone know a solution
Cheers
Spooky4721
01-24-2017 12:20 PM
Hi Spooky4721,
The lines on copies that you are experiencing is a result of the scan glass being dirty or scratched. The scan glass that the printer uses when scanning from the ADF is located to the left of the larger glass area (platen) when you open the cover. It is the smaller glass strip on the left hand side of the unit.
Spray some glass cleaner on a paper towel and then clean the smaller glass area. Once cleaned, try scanning from the ADF again.
Please view this image:
07-04-2017 06:43 AM
Hi, I have the same issue but mine is MP287. I have tried to clean the glass but the issue still occurs. Only happen when try to print a scanned paper.
09-24-2018 04:47 PM
Hello, the suggestion to clean the glass did not work at all. There is a 1/2" vertical bar on the page after you make a copy or scan. I changed the head alignment and the bar moved to right side to the left side. What is causing this and how can I fix it?
12-14-2018 12:25 PM
10-23-2020 10:56 AM
This thick black line has NOTHING to do with dirty glass. A section of the glass scanning rod is burned out and is not repairable.
09-07-2017 05:08 AM - edited 09-07-2017 06:39 AM
I have had this problem for a number of months now on my Canon MG6450.
I don't have an autofeed so everything is done on the platten.
It happens when scanning or copying and appears as a broad bar on the left ie originating from the back of the platten side.
On copies it seems to be just black but on scans you can enlarge it and see it's more complex - see pic which represents the 1 inch width.
This does not seem to be a dirt/cleaning problem.
Any suggestions?
09-07-2017 09:05 AM
Hi, Quarterp!
Welcome to The Canon Forums, and thanks for posting!
We appreciate your participation, though we need to let you know that your product appears to be a model that is not supported by our team here at Canon USA. The Canon Community Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click HERE and select your country to find support in your part of the world.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Thanks for choosing Canon!
01-09-2020 12:49 PM
Was this issue every resolved? I have the exact same problem with my MG3022. Only happens when scanning a document on the platten. There is no feeder on this model so it can't be the ABF.
