Reply
CSG
New Contributor
Re: The latest firmware is on the server. Install the firmware update from (Device Settings) in (Se
[ Edited ]
On the touch screen, you will see "copy:, "scan" and "cloud' icons displayed by default.  If you swipe right with your finger on the screen, more icons will appear on the screen, one of which is Setup (there are also more icons if swiping left, but those don't apply to this particular problem).  I couldn't figure out the very (seemingly) simple instructions displaying on my screen, prompting me to update the firmware, until just now realizing there are more icons available from the main screen.  My firmware has just completed updating.  Thanks for the instructions (although I suggest adding this part on how to get to the "Setup" icon).
New Contributor
I have read the forums on this topic and so far none of them answer my question.
My readout screen has a total of 3 functions I can access: Copy - Scan - Cloud.
I do not have a touch screen that I can swipe my finger over to access the other icons.
I do have, when I press the HOME button, 5 more icons that 'flash on once before my eyes' and although one button is green and appears to have ECO on it and another appeas to be 2 or 3 tools, the rest are gone before I can make them out.  Accessing them is impossible.
There has to be a simple answer to this problem.
Come on CANON people .... somebody, anybody, help me solve this commonly occuring problem.
New Contributor
As you've previously said, you have the three icons on your printer screen. You should notice there is an up triangle and a down triangle above/below the the scan icon. This means there are more options available. On your printer you've probably got a directional control pad, it probably has ok in the middle of it (surrounded with up/down/left/right arrows). if you press the up arrow. You should get new icons on your print screen. including the print setup one. Hope that helps.
New Contributor
I have a PIXMA 6620 - how do I get to the Setup button in order to update the firmware? I went through all my options and can't find the Setup - I should say - I have a Setup but it does not have an option for device settings, just user settings, and printer settings, nothing for firmware; I explored all menus; what am I missing?
Hello.
If you continue to experience the message, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
New Contributor
ronfaulkner wrote:
That was just what I needed having tried all sorts of things.  You have saved me a lot more hassle.  Thanks
New Contributor
Running Windows 10 on a Dell XPS 8500, Canon MG7720.  Got the message but can not find the firmware.
New Contributor
I have a Maxify printer.  I learned that I just needed to slide my finger to the left on the screen and other options appeared.  Setup was on one of these screens.
New Contributor
I have got as far as the message downloading but after a few minutes I get "download failed refer to manual"
Help
New Contributor
I almost got there but it stalled with "Failed to Update, See Manual"
powered by Lithium
