Reply
New Contributor
Re: The bottom of the page always cut off
Had this issue with mg3000 printing tax forms from HRBLOCK software. Printed to pdf first and then pdf printed fine.
New Contributor
TRY THIS.
I was trying to print IRS Form 4868 from a pdf on the web.  An inch of margin was added to the top of the pdf causing the  bottom of the page to get cut off when printed.  I called Cannon support and the guy said it was probably Chrome.  I suspected he was blaming the other guy, but thought of a way to test it.  I downloaded the Form 4868 to my pc, the clicked on it to display it.  I clicked the three dots (upper right corner, Windows 10), selected print, and it printed correctly, without the extra inch of margin at the top, and with the bottom of the page complete.
New Contributor
My exact same problems.  You stated it exactly!
New Contributor
My problems exactly - no matter what programs or web browser/site. You stated my problem very well. If anyone knows a fix, I would appreciate knowing what to do.
Thanks!
New Contributor
I have the same problem with canon MG2500 printer when photocopy my document in A4 size the bottom page is Always Cut off even in print preview . I already made a lot of troubleshoot but it not helps . Im running windows 10 64bit please help me with this .
New Contributor
Had the same problem.
I opened it via a PDF file and checked the printer applicant. On Windows, it sets the default printer to 'XPS Viewer' which tries to squeeze the file together and so the bottom is lost. I changed it to the actual name of the printer (on the drop down list) and it worked. Although everytime I tried to print something, it automatically resets to XPS viewer and so it had to be manually set back every single use.
Worked like a charmed ever since.
New Contributor
Hey try to change the profile settings New Scan from Photo (default) to Documents. Hope it works.
powered by Lithium
