04-19-2016 02:54 AM
Hello. This is the first time I've ever had this problem. I frequent reinstalling my OS whenever it begins to slow down immensely or whenever I'm spooked by the idea that I may have an infection of some type, so I've always had to install my printer's drivers time and time again. This time around I have a new problem and that my printer (Pixma MG2520 as stated in the title) downright refuses to print the entire page.
What leaves me more confused is that I seem to have messed around with what seems to be every setting, taking advice from all over the internet, and reinstalling my printer's drivers a few times to no avail.
It's not that I'm trying to print a document that is sized for a legal document onto a sheet of letter paper, but something that should be printed as a 1:1 ratio. For an example, here is a document I've had no problem printing before and suddenly have a problem with now. Note that the first image is with Fit to page ticked off and the second image is with that feature turned on. Both give me the same results.
Now yes, I do understant that it is just the bottom part of the paper, but for someone who prints out several documents on a monthly basis, it really becomes a problem when I have to keep in mind spacing my document a few paragraphs, sometimes mid-sentence, a few times toward the bottom of each page.
Do you all know of anything I can do to fix this? Thank you for your time.
05-03-2023 01:52 AM
On the page for print choose fit and you'll see that the printed area is inside of bottom margin. I tried so many another settings but nothing help, only when I chose fit the page is printed full.
04-21-2016 08:53 AM
Hello.
The issue may be related to the PDF file itself. Try adjusting the options in the "Page Sizing & Handling" section of the Acrobat print menu to see if this will help.
If the issue persists, you may have to look into getting the item resized for printing on 8.5x11 paper.
07-17-2018 10:47 AM
07-17-2018 10:51 AM
04-21-2016 08:58 AM
04-21-2016 10:22 AM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
07-17-2018 10:49 AM
07-17-2018 10:45 AM
07-17-2018 10:48 AM
10-20-2016 01:19 PM
