Reply
New Contributor
Re: PIXMA mx922 prints blurry.
my canon MX922 prints blurry from the PGBK ink only.  I did all the cleaning and deep cleaning and printer alignment and cleaned the encoder film. Even unistalled and reinstalled the drivers. Nothing helped. Canon knows about  this problem. It is very common. I set my printer to print on Premium Paper (like a photo) and it prints perfectly. This is a defect with this printer. For Canon to let this go is inexcusable. I will use this workaround until I've finished up all my extra ink then I will purchase a different brand.  This is my last Canon printer.
Hi RandyRusconi,
Since the cleanings of the print head and encoder film and alignments have not resolved the blurry printing issue, the printer will require servicing.  We ask that you please contact a Canon technical support representative here to obtain servicing options available to you.  A representative will be happy to assist you free of charge.
Occasional Contributor
The link that you provided isn't working: "This site can’t be reached"
New Contributor
"I set my printer to print on Premium Paper (like a photo) and it prints perfectly."
I was having the same problem on my MX920 - 2 lines would print OK, then about 4 lines would be blurry/misaligned.  It would do this all the way down the document and on every page.  All maintenance methods were tried numerous times but with no success.
I tested switching to Photo Printing and Photo Papers (I chose Matte Photo paper) and either Standard or High quality (it only allows for these two settings) and it worked fine.  Note that I'm talking about the black ink only.  I tested Photo Printing on Standard Paper at different print quality settings and it didn't work...it just reverted back to the 2 good lines, 4 blurry lines deal.
Since it's black ink only, I recommend bypassing the usual Maintenance > Nozzle Check > Print Test Page protocol as this wastes color ink as well as black.  Go to Printer Properties under the General tab, click on Preferences and set the paper ti Photo and ink quality to High or Standard (also be sure the paper size matches your liking).  Click Apply and OK.  Now click on Print Test Page.  This should print out a Windows Printer Test Page that is mostly just text and in black ink only.  Note- you may have to check the Grayscale print option if this page prints in color.
I believe this process uses more black ink, but it's worth it if you need to print.  I only use my printer for mostly signature pages and it doesn't use a lot of ink or need to be in color.  I plan on using DIY refill ink to help compensate for the increased use of black ink.
I hope this helps!
New Contributor
I hope this helps!
Very interesting!
I was able to resolve the blurry printing issue by running the deep cleaning multiple times, but this wastes a ton of ink.
New Contributor
I also have the same issue.  Crisp printing on some lines but with alternating blurry lines at regular intervals down the page.  The blurred lines appear to be a double image where the second print is slightly offset.  Only the black PG-BK jet is affected.
I've tried deep clean & head alignment but neither gave any improvement.  However the photo quality print workaround does work (thanks dkribble) although it's extremely slow.    This workaround rules out the possibility of a roller error as this would effect all colours and print modes....
Guess I'll just have to use up my ink & get another printer from another brand (I'm not encouraging Canon to keep producing poor quality products).
This worked for me Thanks
Highlighted
New Contributor
How should I clean strip to try and prevent blurring
New Contributor
I had tried ALL the suggested fixes from Canon (except calling their tech support) and THIS SOLUTION WORKED for me!!!!! I set my media type to photo paper (kept the quality at Standard) and it fixed the printed alternating blurry lines. Thank you, drkibble, THANK YOU!!
powered by Lithium
