09-27-2017 07:46 AM
I have changed cartridges many times and never had this problem.
I have the printer set to print in Black only.
But every time I go to print, I get a box that says: "Only the following ink will be used for Printing...Black". I then have to press OK every single time. Then it works fine, printing only in black.
How do I get rid of this box and extra step?
09-27-2017 01:22 PM
Jermil, have you tried setting that as the default? That might solve the problem.
if it doesn't, the preferences for your printer are most likely corrupted. I'd locate the prefs file and delete it, then try setting "black and white only" as the default.
good luck!
09-27-2017 01:33 PM
Your quick response lead me to a solution.
In "printer properties" (W10),I set the ink to "Both Color and Black".
In the W10 print dialog, tho, I set it the "color" to "Black and White".
That did it. It now prints directly with no dialog box.
If these didn't work, I like your idea aobut deleting the pinter prefs file.
Thanks so much.
09-27-2017 01:39 PM
Yay! Glad I was able to inspire you to find a solution, because now maybe karma will be on my side. Now I hope someone returns the favor and helps me with my problem.
Happy printing!
09-27-2017 01:52 PM
You have earned good karma.
Hope someone knows the answer to your problem.
12-08-2017 05:36 PM
Hi jermil,
In order to bettr assist you, allow me to ask a couple questions:
I look forward to your reply.
