Reply
Highlighted
Occasional Contributor
Re: MX922 scanner problem message: set the pc to start scanning
Unless you are scanning to a local disk, such as a USB drive, you have to tell the MX922 where to send the scan results, and that must be a computer that can be found on the network.  I believe that usually any machines that have the MX922 defined as an available scanner should be visable as choices to have the scan file sent to them.  I also think that the MX922 should remember the last computer delivered to unless the MX922 has been powered off, in which case you probably need to select a computer again.
New Contributor
 Thank you so much for sharing the simple solution that Canon could / would not!  Your solution was a real time saver for me!!
powered by Lithium
