09-08-2014 03:12 PM
11-17-2014 09:53 AM
Here is what worked for me: 1. Turn OFF Power 2. Open the print head bay (as though you were about to change inks) 3. Turn ON power 4. Wait for print carriage to start moving to the left and let it go past half way 5. Before print carriage reaches left hand side (but after going halfway across) shut the cover. 6. Leave the Printer turned on 7. Good to go. It took 2 attempts before it worked. Some people said it took 3-4 attempts. Now, prior to this, I did clean the pads the cartridges sit on and used a qtip to wipe the encoder strip. I`m not sure if it was the combination of those things or just doing the fix.
Read more: How do I canon mx892 clear error B200? - Printer can`t clear error message B200 how do i clear it off so i can print ? I had a cartridge that was low that i replaced and tried a couple of procedures that did`nt work. :: Ask Me Fast at http://www.askmefast.com/How_do_I_canon_mx892_clear_error_B200-qna7553770.html#q4728865
07-15-2017 08:26 AM
I have done all of these including cleaning thr print cartridge. I have not tried pressing ok 5 times willl try that. Thanks for your help.
Stephen Zappala
02-07-2015 02:37 PM
03-12-2015 03:21 PM
This worked for me. I cleaned the ribbon as well as taking out all the cartridges and cleaning the holder. I think the problem was a cartridge that I had refilled. I threw it away and got a factory one. Didn't want to chance it.
04-16-2015 02:02 PM
worked for me! first try. hopefully it stays that way. i'll update. Thanks so much!
06-06-2015 01:01 AM
Thank you Kdean823 your way to fix this problem did work just fine on the 2nd attempt.
Thanks
06-21-2015 07:16 PM
Worked! Just awesome and thanks ever so much!
06-21-2015 09:24 PM
Happy to be of help. Glad that it worked for you.
Tommy G
09-23-2015 09:30 PM
10-11-2015 09:27 PM
10-17-2015 02:06 AM
