12-08-2016 11:55 PM
I raised the scanner platform on my MF8380CDW and it is now locked in the up position. The directions under clearing paper jams simply states raise the scanner platform, remove any jammed paper, and then lower the platform. There is nothing about how you should release it from the locked up position to lower it A search of the web with Google and a search of this forum only reveals an 8350 user who had a similar problem but there was no solution. How do you unlock the scanner platform so you can lower it?
12-09-2016 09:14 AM
In case someone else stumbles across this, do not look for a lever to press or anything else. The solution is to press the roller near the center of the support holding the platform up away from you toward the back of the printer. Very easy once you understand how it operates.
12-09-2016 09:14 AM
