Canon MG 7150 error message 6000 6001
jacquif2015
hi my machine was making a very loud noise and then the error signs came on there is no paper stuck either.
2 REPLIES 2
Michael
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
jojymu
Following is quick fix to reduce noise in printer:
  • Open the printer driver setup window
  • Click Quiet Settings on the Maintenance tab
  • Set the quiet mode.Always use quiet mode. Select this option when you wish to reduce the operating noise of the printer
  • Apply the settings. Make sure that the printer is on and click OK.Click OK when the confirmation message appears.The settings are enabled hereafter.
Check Canon PIXMA MG7150 Manual for detailed view.
