05-06-2017 02:42 PM
I cannot see any ICC Color Profiles for any of the Canon papers in Lightroom. I do see the Canon papers in the print dialog, however that leaves me with the only option being to have Color Management Managed by Printer rather than by Lightroom. I would expect Lightroom's Color Management to be a bit more robust. All I can find on the web is that profiles are included in the setup software. I am using the latest version of Lightroom CC on a Mac with the latest OS.
05-10-2017 09:53 AM
Give Canon a call at 1-800-OK-CANON.
05-08-2017 10:39 AM
When you try to use a profile for the first time you need to "load" it into Lightroom.
Select the profile dropdown menu, select "Other" and you should get all the installed profiles. Then select the ones you want.
05-10-2017 09:41 AM
That screen is completely blank on my LR instance.
05-10-2017 09:53 AM
05-14-2017 02:47 PM
05-27-2017 09:53 PM
When I called Canon they indicated that ICC Color Profiles for Canon Papers will not show up in Lightroom. Instead, the specific papers are shown in the print dialog (not as profiles, just as paper). Selecting the correct Canon paper there will select and use the correct profile.
Thanks!
