01-30-2014 01:13 PM
This is a "call to arms" for all of you Canon customers who have had this problem and have had their printers disabled because of it. Please respond with the model of your printer and if you were able to fix it, what you did to fix it.
We need to put pressure on Canon to respond this product defect. It appears to be bad firmware that does not allow the user to override the problem and to continue to use the printer even in a degraded mode. From my investigations the problem is NOT a printhead issue - no way one can be printing fine and then have this error alert without having changed the printhead or ink cartridges!
Canon, PLEASE take this issue seriously and provide a solution across the affected models. If nothing else there should be a trade-in allowance for those printers that have been affected by this product defect.
I have had many Canon printers because they have superior functional specifications. I want to be able to continue using Canon products but only if I can have confidence that this product defect will not destroy my investment.
If Canon is unresponsive our next step should be to aggressively publisize this product defect on social media and on major product vendor outlet sites as negatives reviews.
Forum Users, please reply with your affected model number(s) and with details of any succdessful fix procedure.
01-20-2015 07:53 PM
02-03-2014 12:04 PM
This is what I've been able to find so far. 19 posts in 2 of the forums. These represent 36,989 views of the same U052 problem! 16 different models have reported problems:
MG5320
MG5350
MP520
MP530
MP600
MP610
MP830
MP860
MP960
MP990
MP970
MX700
MX882
MX860
MX870
MX892
Where is the Canon Product Quality Assurance Department? This product deficiency should be investigated and a robust solution provided to the thousands of affected Canon loyal customers.
What is your response Canon? Doesn't this warrant a firmware update to correct this product deficiency?
Is it time for a class action law suit?
1- U052 Printhead Problem MX870
by chdevers in Printer/Multifunction Support
Stopped printing while in the middle of a big job with full ink tanks, then when turned back on, gave the dreaded U052 print head error message. I have tried everything given by Canon to re-start...
Show results in replies (5)
05-30-2013 06:19 AM
2- my canon mx892 will not print because of error U05...
by markmarn in Printer/Multifunction Support
our canon mx892 will not print due to error U052. i followed all of the suggested steps for this problem related to an MX700 but it did not correct the problem. now what?
Show results in replies (4)
08-10-2013 05:48 PM
3- MG5320 U052 Error
by JimCarey in Printer/Multifunction Support
I have had the MG5320 printer for just over a year now. Everything has been working brilliantly until recently. I am now getting an error: "U052: The type of printer head is incorrect. Install...
Show results in replies (2)
11-01-2013 04:13 PM
4- My canon MP600 will not print due to error message...
by Shelby27 in Printer/Multifunction Support
Error message - The type of print head is incorrect - install the correct print head. I have not changed the print head - all lights are solid red with the exception of M and C. When you remove them ...
Show results in replies (1)
12-30-2013 06:17 PM
1 Reply
5- Error code u052 on pixma mg5350, says print head n...
by Dendou in Printer/Multifunction Support
09-29-2013 08:15 AM
6- mp830
by mags in Printer/Multifunction Support
I keep receiving an error on the screen of my mp830 that says: Install the correct print head. This started since I put in new ink in all but one ink well...which is the number 5 one, the biggest on...
• Tags:
• U052
05-24-2013 05:52 PM
7- MP610 no longer printing color
by steger in Printer/Multifunction Support
My MP610 has been working reliably and well for years. Then... I received a U052 error ("type of print head incorrect"). By removing the print head and cleaning it with hot water, the...
01-28-2014 12:22 PM
1 Reply
8- MP830 printhead error message
by Maryruthmarks in Printer/Multifunction Support
After I put in a large black cartridge in my MP830 printer, it comes up with a message saying "The type of printhead is incorrect. Install the correct print head" I did nothing differen...
• Tags:
• U052
02-01-2014 08:10 PM
1 Reply
9- MP520 Print Head Problem
by vf32 in Printer/Multifunction Support
I tried to print but got the message, "The type of print head is incorrect. Install the correct print head"
10- Error message on my MX700 Printer: U052 This type ...
by jdegann in Personal Printers
I got this after installing new ink - it worked just a bit and then when I turned printer off and on, got this msg. I took out cartridges and head, put them back in, and no change.
• Tags:
• choc1970
• U052
11-28-2012 09:16 AM
11- Getting U052 (type of printhead incorrect) on my P...
by Islander in Personal Printers
I'm getting a U052 error message on my Pixma MP610 printer. It reads "The type of printhead is incorrect. Install the correct printhead." I replaced an ink cartridge that was running low...
09-01-2013 12:20 PM
1 Kudos
1 Reply
12- U052 error message on my Pixma MP610 printer
by corhoe in Personal Printers
It reads "The type of printhead is incorrect. Install the correct printhead. Whats the solution? corhoe
01-25-2014 05:12 AM
13- Call to Arms for the dreaded U052 Wrong Printhead ...
by macnicol in Personal Printers
This is a "call to arms" for all of you Canon customers who have had this problem and have had their printers disabled because of it. Please respond with the model of your printer and if y...
• Tags:
• U052
01-30-2014 10:13 AM
1 Reply
14- Canon MX700 error message U052, then 5200
by SKS1971 in Personal Printers
Recently, after installing a new black print cartridge, I received the error message U052. I followed the trouble shooting suggestions. After turning printer back on, now I get error message 5200...
02-28-2013 11:52 AM
1 Reply
15- Canon MP990 U052 - print head is incorrect
by jaj in Personal Printers
I have taken the print head out and placed back into the printer - then replaced all ink cartridges - turned printer off - unplugged printer for 10 minutes then turned back on. This error message ke...
08-15-2013 04:38 PM
1 Reply
16- error message u052 canon mx882- printer worked fin...
by ddodds in Personal Printers
Canoon mx882 error message u052 printer and scanner have worked great. Thought i should do some maintence since in 3 years i had never done it. cleaned roller tested ink heads everything ok thgen...
• Tags:
• U052
04-09-2013 09:18 AM
17- how to fix a message from cannon mp530 "check cart...
by gsecondez in Personal Printers
hi, i have a cannon mp530 printer. it stopped printing and a message showed "check cartridge U052". all of the ink cartridge still have ink and none of them are blinking. can you please...
08-23-2013 11:34 PM
1 Reply
18- Any new help on fixing U052 error on MX860?Reinsta...
by eddytsang in Personal Printers
I have been using this printer for a while. No change and it just come out with this error. Is it time to get a new printer? Try the restall print head method. no luck. Any other suggestions? Th...
01-18-2014 10:27 AM
19- My MP970 printer won't print.
by sasa in Personal Printers
My MP970 printer won't print. The message says the type of print head is incorrect. Install the correct print head. This is the second time in two months this problem arose. Last time it just st...
07-31-2013 11:02 AM
04-13-2014 01:09 PM - edited 04-13-2014 01:11 PM
You can ad my MP560 to your list. I turned it on to print 6 pages. The message came up that I needed to replace the magenta cartridge and that the black was low. I didn't replace them but went ahead and did my printing. Then I changed out the magenta cartridge and decided to let it do a print head clean because I haven't used it for some months. Now I get the U052 message and it refuses to go any further. I won't be buying another Canon, that's for sure. I had my old Hewlett Packard for 10 years before it went belly up!
05-01-2014 08:56 PM
I own a Canon Pixma MX892 and have gotten the same message. When I called they convinced me there was nothing I could do so I purchased another printer because I use my printer often. I took great care of my printer and like another person on this forum had just installed new ink, was printing 2 copies of the same document, the first one printed fine and the second one didn't print at all and U052 was showing on the screen. What a disappointment! I thought Canon was better than this, what poor quality! I agree with a class action law suit, something needs to be done!
05-03-2014 01:48 AM
canon replaced my printer after I posted here with same uo52 problem check your inbox for their response I was amazed
05-03-2014 05:07 AM
05-03-2014 05:30 AM - edited 05-03-2014 05:40 AM
I haven't received a mail from Canon
05-03-2014 07:10 AM
My printer is a MP610 and agree that it is a computer or internal logistic problem. My print head is cleaner than .....!
I have seen enough of the complaints to know that it is time to switch brands; no replacement would change my mind.
I am even looking at a Canon camera I own and I wondering what surprise it has in store for me. Canon has decided to be an ink retailer rather than a manufacturer of quality products so it must take the consequences. Good will is easy to lose and difficult to regain. I had an Epson previously so may try them again but will look at the complaints forums first. Perhaps we have to start at the ink and ink heads and work back up to the printer. Sad day for technology.
05-03-2014 09:38 AM
Unfortunately this did not work for me...my printer is making me so angry and the warranty just expired!! Canon what are you gonna do about this?
05-16-2014 07:09 AM
Same problem, owned printer for less than a year and now useless! Will be replacing printer today and will not be a Canon!
