10-02-2013 10:35 PM
I recently installed Digital Camera Solution disk for my Power Shot SX280 HS. When launching Image Browser EX, it gets to 80% complete and returns the error message "Failed to load properly. Verify that Silverlight is properly installed and start Image Browser Ex again." I uninstalled and reinstalled Microsoft Silverlight and still received the same error message when trying to launch Image Browser Ex. I next uninstall and reintstalled Image Browser EX from the solution disk and I am still getting the same error message. Can anyone help me with this.
10-05-2013 09:37 PM
Hi Crockett1119,
Thanks for writing in!
So that we may better assist you, please contact us.
10-11-2013 05:22 PM
I am having the same problem...how can I fix this??
11-14-2013 02:27 PM
I've had the exact same problem since I purchased the new computer with Window 8. Every once in a while the software will load which just drives me crazy. HP(computer manufactor) and Canon has been no help.
11-14-2013 05:43 PM
Hi Swhartlate, I called Canon Support and they were able to walk me thru installing a fix for Microsoft Silverlight from the Microsoft website and it resolved the issue for me
11-14-2013 08:18 PM
Thanks, I might try them again. I tried before and they couldn't help me. Some of their so called fixes would work one time only.
Steve
12-05-2013 08:58 AM
Same problem here. I'm running Windows XP and using Canon ELPH 330. My difference is that I can run Imagebrowser after I installed and using under my computer's admin account. I get the problem when I'm trying to run under the restricted account. I've seen this sort of thing before on XP and was a security issue. However I've not been able to determine the tweaks needed for Imagebrowser. I've read where you can do a reset on Internet Explorer but this don't work for me either.
12-05-2013 09:03 AM
Hi Marshrat99
The solution may differ based on your specififc workflow. So that we can properly customize a walkthrough for you, please contact us here.
