Reply
Occasional Contributor
Re: connect elph 360 wifi to mac
Hold the door ...
I am able to download a bunch at a time. Yeah, this'll work. Frankly, USB is faster, but this will work great when I'm on the road.
Okay, Canon. I'll stay with you.
Cheers.
Just to be clear:
• I cannot connect my Elph 360 to my Mac -- or my Windows laptop running Windows 10 -- via WiFi.
• I can, however, connect to the cloud via WiFi and upload to Canon Image Gateway, Facebook, Twitter, and even Canon's Image Sync.
• The Image Transfer Utility software will not work on my Mac (didn't try it on my Windows laptop) so I can't automatically download to my computer. But I can go to the Canon Image Gateway website and download from the photo gallery. In some ways this might even be better since I can cherry pick the ones I want.
Unless I'm on the road, I'm inclined to upload via USB, but the ability to post to Facebook and Twitter from the camera is very cool.
Cheers,
Mike
Hi Austincameraguy,
You should be able to connect to your Windows 10 machine. What happens when you try this connection (errors, etc)?
Richard -- Give me a couple of days and I'll try again and take notes.
Mike
Ahhh. Thanks for letting me know that. Saves me some time.
New Contributor
this has been nothing short of a gong show trying to connect the cannon elph 360 to wifi to download pics on my computer,
had i known  this was the issue i would NOT have purchased, why is there no option to hard connect to a macbook pro, i have followed all the directions and suggestioins,  nothting works, and often i am on holidays in areas with NO wifi, so whats the point, im not going to carry around  dozens of scan disk  things to save my photos,  there needs to be some solution
New Contributor
[ Edited ]
Just bought the ELPH 360 HS. No luck connecting to a mac. I can join the network fine, and I can see my mac, but when I run the the CameraWindow app on the mac, it just says no camera found.
How can they release software that just doesn't work? Do they not test it at all?
Running macOS 10.13.3
If you look at how it's launching the actual app in terminal, there are errors:
/Applications/Canon\ Utilities/CameraWindow/CameraWindow.app/Contents/MacOS/CameraWindow ; exit;
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.30.2/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.30.2/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.30.2/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist'
Common Cannon. Get with it. How are you releasing software that fails on launch. Very unimpressed. :-(
New Contributor
Get this, canon support replies with
"Your Canon camera wifi function is not compatible with latest versions of the MAC OS 10.11 10.12 and 10.13."
Basically, you have to be running an outdated old useless version of macOS. Nice job canon. How about releasing software that works with recent versions of operating systems.
Super Contributor
" but when I run the the CameraWindow app on the mac, it just says no camera found. " by shamusom
The canon camera window app in the -add a device folder- of your computer maybe not be a complete software  ( needs driver ) thats why when you open it - it will not work - and it says " no camera found "
Search how to download manually the camera window app. Compatibility issues is rarely the cause.
New Contributor
I've tried running every version I can find. Simply does not work. Dissapointing for sure.
powered by Lithium
