02-14-2018 07:53 PM
02-15-2018 02:42 PM
The NB-6L battery is 3.7 V, but it is unclear how much current it can supply. It is rated for 1000 mA hours, which implies that it can supply 1 Amp for 1 hour. That says to me that your D-DC converter must be able to supply at least 1 A. Batteries can supply very high peak currents, so that might be too conservative, you might need up to 3 A.
02-15-2018 07:28 PM
Thank you for the answer. The maximum amps of the Buck regulator I am using is 2.5A. I don't think the buck regulator is the problem. With the A/C adpater 4.3V rated at only 1.5A works fine. I took several spare A/C adpaters and put them through the same step down regulator. I tried a regular 9V 1A, laptop 19V, 2.5A, 2A and 3.5A, they all work fine. But when it comes to battery it does not work. I have already listed the batteries I have tried. Even the laptop battery which is 14.4V 4.5A did not work (I am sure a laptop draws lot more current than this camera). So, there must be some other factor.
02-16-2018 09:20 AM
" The camera turns on but turns off immediately as if there is not enough power".
This is a camera protective procedure not to further damage the camera. No way to exceed the ampacity of the battery except only until its allowable tolerances. Use only its true charger. The best way is to have spare batteries and not explore how to prolong battery life.
Do not frequently off/on the camera because its RLC circuit use a maximum current in the first three milliseconds after power is on. Yes the flash use too much current, Only way not to use it is lighting the room/area of concern.
02-16-2018 09:56 PM
Thank you very much.
02-17-2018 08:27 AM
You are very welcome.
