05-13-2018 06:41 AM
HI,
Can I add an additional wide lense? Can you please send a link with the part?
Thank you in advance.
05-13-2018 09:31 AM
@rnagar wrote:HI,
Sorry, I do not have a part number for you, just some advice. A quick look at the Canon Online store did not turn up any supplemental lenses, just filter adapters.
Many compact cameras have filter threads, which allow you to add a light filter. There are also supplementary lenses that can be purchased to change the focal length, such as make the camera behave as it were using a super wide angle lens.
Be aware that anytime you had something into the light path before it reaches the image sensor, that something will degrade and alter the light to some degree. Nothing comes without a price, and using a wide angle converter change the behavior of the camera, most probably the ISO range, the aperture range, and the focusing speed.
