05-31-2018 12:27 PM
I'm visiting Alaska in ten days time and would like advice on the best setting for still and movie shots in snow or very bright surroundings. I can't find any "snow" type settings in "PowerShot_SX430_IS_SX432_IS_Camera_User_Guide_EN.pdf".
Any advice would be appreciated!
Thank you.
05-31-2018 12:36 PM
Sometimes the evaluative metering is smart enough to automagically compensate for sand or snow. (I was just at White Sands and my exposures were fine on my T6S.)
Take a shot of a white wall/sheet in direct sun. If the picture comes out white, you are good to go, if it comes out grey, you need to add about 2 stops of exposure compensation.
05-31-2018 12:36 PM
05-31-2018 12:54 PM
A shot of a white wall in direct sun and with a clear blue sky behind it came out perfectly with the camera on Auto! I should have had more faith in the technology!
Many thanks - I'm good to go!
