12-04-2015 12:12 PM
The date and time menu constantly resets itself to zero. I have to input the correct values several times a day. Is there a fix for this??
12-04-2015 02:05 PM
Thats an easy fix your date and time battery is most likely dead and needs to be replaced it is a CR1220
12-13-2015 09:35 PM
12-04-2015 02:05 PM
12-13-2015 09:35 PM
12-13-2015 10:58 PM
Your quite welcome I forget the silliest things also from time to time too lol
02-01-2018 07:02 PM
It is now Feb. 2018. I have the same problem. I bought a new battery. It still does not work. The date again reset to zero when I powered off. Any help would be very much appreciated.
Thanks.
02-01-2018 07:07 PM
Hi ML2018!
Thanks for joining and posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback.
If you are in the United States and this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
If you live outside the United States, please click here and select your country or region for your support needs.
We hope this helps!
02-01-2018 07:35 PM
Thanks for the reply. By luck I solved the problem. I suspected that it was a contact problem. The bits of metal in the small cavity were very flimsy. I tried adding a small piece of aluminum foil on the side with a bit of tail haning outside (so it won't fall in) and inserted the battery again. It is now working well. This means that the contact point for the battery on the side is not tight enough.
The reason I suspected the contact problem because it was also the contact problem for the CR1220 cavity in one of my older canon cameras a few years ago.
02-01-2018 07:46 PM
Excellent detective work!
02-04-2021 01:04 AM - edited 02-04-2021 01:08 AM
Folllowed all the steps to contact support and it told me that I need to purchase wannty coverage.
One would think in this day and age of the smartphone digital camera, manufacturers would be humble enough to at least offer chat support free of charge.
02-01-2018 07:19 PM
Well lets just hope you got a bad brand new CR1220 battery because that is what maintains the date/time you set. I would try another battery and make sure it is in there correctly although I dont think it will fit if the battery isnt in the right way. Also look inside the battery compartment with a flashlight for any signs of a problem of debri in there. I got my fingers crossed it was just a bad battery
