01-04-2017 01:34 PM
I just purchase an ELPH 190IS and I've tried everything to get it to connect to my laptop and nothing works, it always fails. I am running windows 7 64 bit home and school. Any suggestions? Thanks, Mike
01-05-2017 10:10 PM
Thanks everyone, I stumbled across this Cano youtube video that made the wireless connection easy.
https://www.youtube.com/watch?v=-xcwUAVdpCg canon youtube wireless 190 setup windows device.
It had an extra step I did not see anywhere else.
Thanks again everyone
Mike
01-04-2017 01:39 PM
Did you try a second USB cable?
01-04-2017 04:54 PM
I'm sorry, I should have said I can't get it to connect wirelessly. I don't have a usb cable yet. I'm glad I received an email saying that someone had responded. I'm on 2 other forums and I can't get it set to notify me when there has been a response. Thanks, Mike
01-04-2017 06:10 PM
Do you have a wifi access point (router) or are you trying to hook directly to the computer? It looks like you have to have a network access point you cannot make an ad hoc connection to the computer.
Apple or Windows?
01-04-2017 10:07 PM
Yes, Im trying to connect wirelessly (I bought the camera so I could do that). I've followed all the instructions in the book and different ways at
http://www.canon.ca/support_images/wifits/pdf/PS-Sending-images-to-a-computer-Wi-Fi-function.pdf online and it always failed. When it says on the access point hold down the WPS connection button for a few seconds I push the wireless button on the front of my ATT 3801HGV gateway and it thinks for a while and eventually fails. Thanks, Mike
01-04-2017 10:45 PM
Sounds like you are doing it right. Did you try the alternate connection method?
You might want to call Canon.
01-04-2017 10:59 PM
I've tried everyway I can and it always failed. I just connected the camera with a usb cable and the drivers were installed and the camera shows up in my computer but not when I unplug it. Sometimes when it is searching it finds the computer but still fails. Thanks, Mike
01-04-2017 11:02 PM
When I turn the camera on while plugged in it comes on for a second and then goes blank. Thanks, Mike
01-05-2017 07:47 AM - last edited on 01-05-2017 09:45 AM by Danny
The usb cable I have does not have the round cylinder (for lack of a better term this early in the am) like this one ([link removed per forum guidelines]). It is just a round cable. Do you need the other cable to charge and dl pics. Thanks, Mike
01-05-2017 07:51 AM
@wmh9680 wrote:The usb cable I have does not have the round cylinder (for lack of a better term this early in the am) like this one (http://www.marttree.com/canon-powershot-elph-190-is-computer-cable.html). It is just a round cable. Do you need the other cable to charge and dl pics. Thanks, Mike
The round cylinder that you are referring to is a balun, which is an electronic device to reduce noise on data lines. The lack of a balun strongly suggests that the particular cable either does not have data lines, or susceptible to external noise on its' data lines.
