Reply
Occasional Contributor
Can't upload photos via USB cable/SX720 HS
This camera is causing me "conniptions". It took me a week to fix the problem of being unable to upload photos via WIFI and now this! I was, prior to having WIFI issues, uploading my photos to my computer via the USB cable. I had no issues. Then I had WIFI issues when I traveled which I had difficulty correcting. I eventually fixed the issue. However, I then found I could no longer upload my photos using the USB cable. In fact I thought the cable must be faulty so I ordered a new one. Same problem. Yesterday I eventually started up an old laptop and had no problem uploading my photos from my camera to the laptop, using either of the two cables I now own. However, I cannot get the photos uploaded to my desktop, even though I was doing so for several months prior to the WIFI issue. I have tried everything I can think of and looked at all the help files, and still unable to upload. Please help!!!
I might add when I had the WIFI issue and contacted Canon I found the "support" unhelpful. They clearly didn't read my emails as they told me things I had already tried and mentioned in the emails, and when I tried to call I got a constantly busy response and never got to a customer  service person. I eventually did correct the problem myself but it took over a week.  I have owned Canon cameras for the past 25yrs and never had issues. I own an EOS which I use locally but bought this small camera for travel, and it is giving me a lot of issues. Any advice on fixing this issue will be appreciated.
Esteemed Contributor
Re: Can't upload photos via USB cable/SX720 HS
Turn off wifi when you use the cable.
I do not see how to turn Wifi completely off. I turned the NFC off. Made no difference. However, I don't see why this would matter as I wasn't doing this previously. I had Wifi operational AND could still upload photos so what is different? When I click on the "upload" from camera in my photos file, that I used prior to 2 weeks ago, it says it can't find anything to upload. There are more than 700 photos on the camera. Plus it uploads to my laptop. It is just confusing.
Super Contributor
What is the desktop computer OS?
Need to clarify that you mentioned NFC off -  you want transfer  to cell phone via usb?
Do you have SD card reader in your desktop computer?
You have mentioned that is working before and now no more using usb cable transfer to desktop computer?
Honored Contributor
The camera is not smart enough to know use Wi-Fi or USB by itself.  You must tell it which method to use, one or the other.  If you believe that the camera once figured it out by itself, you are mistaken.  It was just coincidence that worked in your favor.
Super Contributor
"The camera is not smart enough" ...
The questions was not answered and no idea how to go on, incomplete info will give incomplete solution. Remember that the operator operates the camera/computer  and not the camera/computer has to think by itselt.
Still no_one has explained how to turn Wifi off. I have gone through all the menu items and do not see an "on/off" on wifi. Could someone explain it step by step?
Super Contributor
... explained how to turn Wifi off...
Select any method you want if you are using windows 10:
1)  At the bottom right  screen notification area click on airplane icon and click wifi to off the function.
2)  Click on windows logo: type in internet connection troubleshooting,at network and sharing center, change adapter settings, see at upper left- wifi  can be off.
Hi Nagal,
Thanks for posting.
With regard to your camera's Wi-Fi setting, there's no need to turn it off. This is an issue for a few EOS Digital SLR cameras.
If you're still unable to transfer via USB, from your description, it sounds like the driver for your camera has become corrupted and needs to be removed and reinstalled.
Which operating system do you have on your computer?
powered by Lithium
