05-28-2013 12:06 AM
The ON/OFF button only turns ON my camera, I turn it OFF opening the battery compartment. When I press the ON/OFF button nothing happens and the lens does not go to home position.
Is there a way to fix the trouble?
05-28-2013 12:31 PM - edited 05-28-2013 12:35 PM
Take the battery out ASAP and put it (camera) in a dry place for a couple of days. If you happen to have some desiccant (those little packets that comes in new shoes or in vitamins) toss those in a box with the camera. All you can do is hope.
If you're feeling courageous you can try to remove the housing (I don't know if it's glued or screwed together) to aid drying and mop up any water, clean any salt bridges that may cause shorts. Your warranty is already void because of water damage, so you don't have much to lose. If you can't get it open without cracking the case then wait a few days and see if it works after drying out first.
05-30-2013 09:10 PM
Hi Siulpaz,
You may be able to draw the water out using a desiccant, as Skirball suggested.
We don't recommend disassembling the camera, however. Should service be required, please click here for service options.
